engine replacement - Taurus Car Club of America : Ford Taurus Forum
Old 01-14-2013, 08:33 PM   #1 (permalink)
Member Number: 52272
Drives: 2004, SE sedan, 3.0 vulcan
2004silverbullet is an unknown quantity at this point
Default engine replacement
i have an 04 se sedan with a 3.0 ohv vulcan thats been running almost 16,000 on a bad engine ( heavy knocking). but now that i have the money, i wanna replace the engine and id like 24v duratec. are the transmissions for the two different or should my current transmission match up with a duratec too?
2004silverbullet is offline   Reply With Quote
Old 01-14-2013, 08:38 PM   #2 (permalink)
JIMMER's Avatar
Member Number: 32379
Drives: 2002 Taurus SE 3.0
JIMMER will become famous soon enough
Totally different trannys (bell housings.)
James
2002 TAURUS SE - 3.0L VULCAN - 5 SPEED
TORONTO, ONTARIO.
Ride of the Month - Sept. 2011 - coolfords.com
Ride of the Quarter - 1st Quarter 2012 - teamtos.ca
Car of the Month - July 2012 - TCCA
Car of the Year - 2012 - TCCA
Video: http://www.youtube.com/watch?v=-nbtyJTC9QU
JIMMER is online now   Reply With Quote
Old 01-14-2013, 08:51 PM   #3 (permalink)
Breeves002's Avatar
Member Number: 49890
Jimmer said it all. You would need a new transmission as well to pair it with the duratec.
2012 Kia Soul Base AT 1.6GDI
CLICK HERE
Old 01-14-2013, 08:54 PM   #4 (permalink)
JIMMER's Avatar
Now you could find a 3.0L SHO engine. Same bell housing. But it would require fab work, like mounts, etc.
James
TORONTO, ONTARIO.
Old 01-14-2013, 09:36 PM   #5 (permalink)
Seriously Senior Member
The White Falcon's Avatar
Member Number: 51308
Wouldn't it need to be a 3.2L SHO engine, since that's the one designed to be paired with an automatic?
Bradley.
Holly: 2003 Ford Taurus SES Deluxe, built in Chicago on 11/08/2002. Duratec 24V DOHC, with Luxury and Convenience Package, moonroof, CD changer, and XM Radio. Mods: "Amazing" Stock Audio paired with Pioneer speakers, woodgrain interior, tinted taillights.
The White Falcon is online now   Reply With Quote
Old 01-14-2013, 11:35 PM   #6 (permalink)
Member Number: 4817
Drives: 1992 Taurus SHO
Cool
it would be better to just buy a Duratec equipped Taurus unless you are really handy as you will need the entire front end to make it happen.
You would need almost a whole front end to make it happen. I know at least 1 person did it and they said it was not worth it due to the work involved.
Yes a LOT of work.
It is not "made" for the ATX per say, it just has a slight bit more power. Either one would work.
92 White SHO
http://www.shosource.com
Old 01-15-2013, 12:21 AM   #7 (permalink)
Breeves002's Avatar
Loudsho - are the trans bolt pattern for the bell housing on the 3.0 and 3.2 sho motor the same?
CLICK HERE
Old 01-15-2013, 11:43 PM   #8 (permalink)
Member Number: 4817
Cool
Yes they are the same. I just bolted an MTX to a 3.2.
92 White SHO
Old 01-16-2013, 12:15 AM   #9 (permalink)
Member Number: 45250
Drives: 2002 Ford Taurus SES. 24V Duratec. Metallic Gray. :)
Simon182 has a spectacular aura about
Off topic, but since the transmissions are different, does anyone know which one is the stronger one(lasts longer with less problems) Vulcan or Duratec?
Simon182 is offline   Reply With Quote
Old 01-16-2013, 12:20 AM   #10 (permalink)
it'sthatcar's Avatar
Member Number: 49561
Chapter: Northern
it'sthatcar is on a distinguished road
Both engines are solid and dependable. That being said, each of them has it's own set of common issues. I have had Taurii with both engines and prefer the Duratec that I have now. I like the extra power and the extra 'growl'.
it'sthatcar is offline   Reply With Quote
