#11 (permalink) | |
Member Number: 3408
Drives: 1997 3.0 OHV
Rep Power: 9 ![]() |
The debate has been endless here. Each is good. The Duratec has more HP. A more modern engine. I have the 3.0 Vulan. It is slower then the 3.0 Duratec I had a few years ago. I drive much more cautiously now. Comes with age. So the slowness of engine makes no difference. Highway speeds it makes no difference. Some claim that the 3.0 Vulcan OHV is more durable while others state that the more modern 3.0 Duratec is more durable. Much depends on how you take care of car and what type of person drove car when new - if you purchased a used one. |
#12 (permalink) |
![]() Member Number: 49890
I like the duratec better. Everyone has their own opinions, but I feel that it is slightly more reliable, and also has that extra oomph.
How easy it to swap between the 3.0 and 3.2? Do you have to fAbricate custom mounts, etc? Not planning on doing it, just curious. Sent from my iPhone using AutoGuide.com App
#13 (permalink) | |
Taking Care of Business
Member Number: 40467
Drives: 2004 SEL Duratec
#14 (permalink) |
#15 (permalink) |
Member Number: 32683
Rep Power: 3 ![]() |
A 3.0/3.2 swap wouldn't require "custom mounts", it would require drilling new holes in your subframe, or, a complete subframe swap.
Sounds easy, but that's as easy as it gets. Fuel system, and wiring would have to be completely fabricated. A/C hoses, PS hoses, vacuum, etc. etc. would all have to be custom made. It's not impossible, but don't ask how I know this.
#16 (permalink) |
Member Number: 36955
This is probably way off topic but I saw a Ford Probe with manual transmission in the yard yesterday and I know Jimmer has the manual trans from one. Are all Ford probe manuals transmissions the same and could it be paired with a Lincoln continental 4.6? V8 engine that was succesfully transplanted in the Gen3? Would they both work in an 04 without serious issues? Also with is the make and model/ engine number off the Lincoln engine that will work?
1989 Ford Escort (RIP)1988 Ford Taurus GL(RIP) 1995 Ford Taurus GL(RIP) 1993 Ford Taurus LX(RIP) 2004 Ford Taurus SES [Current ride] Last edited by Blkfordtaurusman; 01-16-2013 at 05:49 PM. |
#17 (permalink) |
If it has a Vulcan in it, then it will bolt up to any other Vulcan.
#18 (permalink) | |||
Member Number: 4817
Drives: 1992 Taurus SHO
Rep Power: 15 ![]() |
1. Cut off some extra material and drill and tap. 2. Swap on 3.0 heads which I did. Either way you need to swap over 3.0 accessories. Yes but the accessories are very different. Quote:
92 White SHO ![]() -Performance: Turbo 297hp 279ftlb -Drivetrain: CM Clutch,SHONut Mounts,QUAIFE -Suspension: SS Coilovers, 24/26mm,Poly,Gen3,H-Brace, Subframe -Brakes: Cobra front, 11.6 rear -Looks: Sound System,Speedhut,Pilot Fogs,Clear Corners,Gen2 Console, CF Cowl Hood & Trunk http://www.shosource.com |
