Basic Mods? - Page 3 - Taurus Car Club of America : Ford Taurus Forum
post #21 of 29 (permalink) Old 01-02-2013, 06:26 AM
JIMMER's Avatar
[quote=loudsho92;1726994]
Originally Posted by JIMMER View Post
Okay cool.
You might want to tell my SHO motor with boost about that...
Yes, but based on your numbers, you are running fairly low boost, I would guess around 8 psi. I tend to be more of a boost junkie, 20+.
James
2002 TAURUS SE - 3.0L VULCAN - 5 SPEED
TORONTO, ONTARIO.
Ride of the Month - Sept. 2011 - coolfords.com
Ride of the Quarter - 1st Quarter 2012 - teamtos.ca
Car of the Month - July 2012 - TCCA
Car of the Year - 2012 - TCCA
Video:
JIMMER is offline
post #22 of 29 (permalink) Old 01-02-2013, 08:17 AM
Roach's Avatar
The SHO motors are built a little stronger from factor then a Duratec. With that being said you can add a little more boost before having to completely rebuild it.
2000 Taurus SE "Lady Hearse"
__1995 Taurus SHO "Organ Donor"
____1996 Thunderbird LX "Jade Phoenix"
Roach is offline
post #23 of 29 (permalink) Old 01-02-2013, 01:10 PM
QuinnSHO's Avatar
BOOST WARZ!
I agree with Roach. Now if you're planning on running a boost ***** amount, you're gonna want to be rebuilding. Now, it sounds like that isn't your plan though. A little bit of boost, *if you get some shop help, they can modify the headers to work. One of the shops actually told me to get headers from a turbo'd car rather using my own. Different shops have different ways*
As for that trans, I'd say a Doug build and tune.
So you got a turbo
headers
(Those 2 contradict the other unless, again, you find a way to make both work)
Tuner
Doug (or equivalent) trans build.
Another route is a supercharger (?)
QuinnSHO is offline
post #24 of 29 (permalink) Old 01-03-2013, 03:50 PM Thread Starter
Thus far here is what I've come to figure out from this thread.
Shift Kit w/ tuner
Remove intake silencer. (I suppose this would allow more air flow, and probably make it louder.)
K&N Air Filter, or some type of Cold Air Intake
Exhaust(Not sure which would be best, but I'm guessing a low flow.)
Headers (If applicable to engine)
Tune
Will this help with at least 20-25 HP gains? Also, a link to a few sites to grab the parts would be awesome. Am I missing anything from the list?
Monster SRT is offline
post #25 of 29 (permalink) Old 01-03-2013, 11:05 PM
Cool
Shift Kit w/ tuner
Tune
Just that there are no headers available for the Taurus Duratec. You will have to make your own or mod a Contour set.
Shift kit will require a rebuild.
92 White SHO
loudsho92 is offline
post #26 of 29 (permalink) Old 01-03-2013, 11:24 PM
breeves002
Sam's Avatar
Year: 2008
Engine: 3.5L Ti-VCT V6
Trader Score: 8 reviews
What about putting a 5 speed manual in? They bolt right up from the Contour right? I'm curious if anyone has ever done that to a tec. How do the electronics work? Sorry to hijack the thread.
2016 Ford Mustang GT Premium
2014 Ford Focus Electric
Moved On:
2008 Mercury Sable Premier
2000 Sable LS Premium Duratec
1997 Mercury Grand Marquis GS
Sam is offline
post #27 of 29 (permalink) Old 01-04-2013, 12:15 AM
Cool
It is possible but it is not something you can easily drop in. You need to get the clutch and shifter assembly to work out. You will need to fabricate a new transmission mount. You will also need to tune for having an MTX.
92 White SHO
post #28 of 29 (permalink) Old 01-04-2013, 12:18 AM
breeves002
Sam's Avatar
Year: 2008
Right. Just was curious how the electronics work. Just a tune is all that needs to be done electronics wise?
Moved On:
Sam is offline
post #29 of 29 (permalink) Old 01-04-2013, 03:47 AM
JIMMER's Avatar
After my 5-speed swap, the ECU sometimes kicks in a rev limiter at 4K rpm. It feels the car moving, but does not sense a tranny, so it will sometimes kick in the limiter as a safety precaution. I will be upgrading the ECU after the stroker motor is done, to the new AEM INFINITY stand alone. Right now, I can power through the limiter if I want, or get to the limiter, downshift, punch it, then upshift.
James
TORONTO, ONTARIO.
Video:
JIMMER is offline
