95 sable trans problems - Taurus Car Club of America : Ford Taurus Forum
Old 12-24-2012, 09:34 AM   #1 (permalink)
Member Number: 51891
Drives: 95 sable base model 3.0
95sablewb is an unknown quantity at this point
Default 95 sable trans problems
Hi this is my first post here so bare with me . I have a 95 sable with the 3.0 it has the 19 bolt pan ( don't no if it makes a difference ) . I bought the car cheap and it is my daily driver since I got it the trans has acted up. Here's wat it does, if u take of fast it won't shift out of 1st it will just hit rev limiter until u let off,it will also completely disengage around 40 then u can rev it up and will grab for a second then disengage again. So I did some research and found similer problems saying it is the vss so I changed it and it made no difference I also changed the abs sensors to the same result. So as of now I am driving it with the vss unplugged since it drives better this way I no its not rich but I don't no wat it could b . I figure it is something electrical.any help is much appreciated thank
95sablewb is offline   Reply With Quote
Old 12-24-2012, 01:09 PM   #2 (permalink)
Lgbpop's Avatar
Member Number: 7489
Have you check the transmission fluid yet? (Needs to be done when the tranny's warmed up, after 20 minutes or so of use)
No insult intended. but after Clark$ I leave nothing to chance...
Old 12-25-2012, 03:07 PM   #3 (permalink)
Ya checked that its all good . It runs so much different with the vss unplugged so I figured it was something electrical .
Old 12-26-2012, 04:27 AM   #4 (permalink)
Member Number: 20835
jacjm has a little shameless behaviour in the past
you and i have the same problem,,,,i changed the trans range sensor, with no luck,,,1995 taurus AX4N
jacjm is offline   Reply With Quote
Old 12-26-2012, 11:18 AM   #5 (permalink)
sheila is just really nice
^ Might check/clean/replace iac (idle air control).
Old 12-31-2012, 05:11 PM   #6 (permalink)
I forgot to menchikn that the car satTfor around 6 months before I bought it
Old 02-04-2013, 11:02 PM   #7 (permalink)
Member Number: 889
Scan the engine computer for trouble codes & post All code Numbers, as they can provide good trouble shooting clues. Inspect the speed sensors wiring & electrical connector pins/sockets for corrosion, bent pins. or spread loose fitting sockets, or damaged wiring. Was the speed sensor connected to the tranny dipstick/fill tube, or has it been flopping around loose????
Your right to have the speed sensor & TRS on the suspect list. Also consider having the tranny computer scanned for trouble codes & post All Numbers.
99 Ranger 4dr 4.0L 5spd Auto
Payload & Tow Pkg
