03 wont shift automatically after work estimate - Taurus Car Club of America : Ford Taurus Forum
Old 12-24-2012, 07:58 AM   #1 (permalink)
Member Number: 14860
Drives: 2002 sold 2003 Sisters SEL
robdog has a little shameless behaviour in the past
Default 03 wont shift automatically after work estimate
My sister took her car to have a clunking noise checked out, they said it was a broken trans mount. Now the car wont shift automatically but you can do it manually. Im going to look at car today and thought somebody might have some input on this? I will look into taking it back to where she took it but ya know how that usually goes.
Thanks, Rob
MERRY CHRISTMAS!!!!
robdog is offline   Reply With Quote
Old 12-24-2012, 12:22 PM   #2 (permalink)
Ok, I went and drove it today. It didnt start having problems till a few weeks after in for the check so not anything they did.
If you put it in drive it wont go into gear or will slip from a stop, if you take off in 1st it takes off fine then you shift to drive after you get going it will change through the rest of gears with no slipping at all.
Is it fixable or time for another trans?
2003 Has 120K on it, I can get a used with 78K for $350 and install it myself. Is it worth the time and effort or is 78K just another trans getting ready to go out also?
Thanks, Rob
Old 12-24-2012, 03:28 PM   #3 (permalink)
The Page 93 Mastermind
TaurusDailyDriver's Avatar
Member Number: 42443
TaurusDailyDriver has a spectacular aura about
There is no telling when the new (used) tranny will go.. so it is hard to say. It all has to do with how it was driven and maintained.
If you end up doing it yourself, it is a risk well taken. Even if the new tranny goes at 120k like your current one, you will have saved a lot on labor costs anyways. It could go to 160k.. or 100k.. you never really know.
Paul T.
|2006 Taurus SE | Silver Frost |The 'Official' Bull of Central New York! | October 2012 COTM
|2005 Taurus SEL| Vibrant White | The Stock Bull
|1999 Taurus SE |
Toreador Red | Retired with 112k
TaurusDailyDriver is offline   Reply With Quote
Old 12-24-2012, 08:57 PM   #4 (permalink)
Cool thanks, I think I have to give it a try as she cant afford a trans from ford.
Merry Christmas!!
Old 12-25-2012, 08:22 AM   #5 (permalink)
AX4N 4F50N Transgo SK®AX4N Transmission Shift Kit® Fits '95 Ford Mercury Linc | eBay
Maybe this would fix it?
Old 12-25-2012, 10:33 AM   #6 (permalink)
Member Number: 1771
A more through diagnosis is needed to determine "what went out". SOmething failed. Valve body issue? Torque converter splines strip out? Pump shaft strips out/fails?
Sold....
Scrapped...
Old 12-26-2012, 01:38 PM   #7 (permalink)
ringo234's Avatar
Member Number: 51304
Drives: 2003 Sable LS Premium
ringo234 is an unknown quantity at this point
I bought a 2003 Sable on Easter 2012. It started jerking when I would but it in drive (not in reverse though) soon after I bought it. Other than the jerking problem the car ran fine. I had the motor mounts and trans mounts replaced but it didn't fixed the problem, luckily I had a 90 warranty and the trans was rebuilt. I'm not sure if this a common problem or not but I got a 1 year warranty after the rebuild.
ringo234 is offline   Reply With Quote
Old 12-26-2012, 08:29 PM   #8 (permalink)
I talked to my trans guy today he said it was the low roller clutch or something like that and said the 350 on the used trans was a good deal. I will pick it up tomorrow and give it a try. Better then the $2200 ford wants for a reman.
Thanks, Rob
