ax4n/4f50n interchangable ?? - Taurus Car Club of America : Ford Taurus Forum
Old 12-09-2012, 06:34 AM   #1 (permalink)
Member Number: 20835
jacjm has a little shameless behaviour in the past
Default ax4n/4f50n interchangable ??
will the 4f50n mechanically swap in place of an existing ax4n ?? if it does, what kind of electronic problems are expected ?? are the 4f50n's even worth the trouble to consider such an idea ?? (haven't seen too much reliability info on them). if the concensus is they are more reliable, and CAN BE swapped, i would prefer to do that, because i am keeping my old bull "FOREVER!!"
jacjm is offline   Reply With Quote
Old 12-09-2012, 08:48 AM   #2 (permalink)
Member Number: 1771
The trans for your car needs to come from that year or, from whatever compatible years are spec'd for it from the Hollander interchange.
Sold....
Scrapped...
Old 12-10-2012, 07:40 AM   #3 (permalink)
major's Avatar
Member Number: 10385
Drives: The 1999 Taurus wagon is back.
major is on a distinguished road
I'm not sure what year you have but, Hollander Interchange for 3rd and 4th gens are:
AX4N (4F50N) or AX4S. Must be replaced with the same type of transaxle.
1996 - 1997 same.
1998 one year only.
1999 one year only.
2000 one year only.
2001 - 2003 same.
2004 - 2007 same.
Vulcan OHV motors must be matched, Duratec DOHC transaxles will not work on a Vulcan and vise-versa.
SHO AX4N is the same 1996 - 1999.
major is offline   Reply With Quote
Old 12-10-2012, 08:26 AM   #4 (permalink)
WOW, BULLGEEK- you sure are on top of things. as you already know my troubles, i am trying to find a RELIABLE fix for my car. i don't mind swapping a trans if it means miles and miles of trouble-free, happy motoring (AS A LAST RESORT, of course). in the meantime, i haven't had time to fool with it (i am working on ANOTHER car to get me to work). i really do not understand. as long as they physically bolt in, what does the car care what year the trans is?? i DO understand there will be electronic issues, but can't that be overcome ?? when i DO get a chance to look at it, i want to get it on ramps, and check everything going to it. do you have any other ideas as to what may be going on ?? i AM OFF today, so i may get some time to waste on it. it hurts my eyes, seeing it sit there, undrivable.
Old 12-10-2012, 08:51 AM   #5 (permalink)
KhanTyranitar's Avatar
Member Number: 28289
Drives: 1996 Ford Taurus LX Wagon
KhanTyranitar has a spectacular aura about
The reliable fix is simple, have a master trans builder make i reliable. The only part hat gets complicated is cost, and making sure the builder knows what he is doing.
My trans is over 170,000 miles now, bought it with 138,000 and no OD and was told it had "lots of wear". Despite that, they made a couple mods to the valve body, and it has been great ever since.
KhanTyranitar is offline   Reply With Quote
Old 12-10-2012, 11:07 AM   #6 (permalink)
sheila is just really nice
Jacjm, carefully read major's post.
Old 12-10-2012, 11:53 AM   #7 (permalink)
yeah, i did. OK, anything special about it ?? just to mention, i am dealing with a 1995 taurus, 3.0l vulcan engine, with the AX4N atx. it doesn't want to shift right. it started out not shifting out of first (25 mph- max). then i cleaned some grounds (per BULLGEEK's advice) ,,now it won't shift out of second (35 mph-max). i am GONNA FIX THE PROBLEM, the big Q is, how long will it take and how much will it cost ?
Old 12-10-2012, 12:02 PM   #8 (permalink)
yehhh, that SURE IS simple. if i HAD the money to do that, i wouldn't be trying to drive a 17 year-old-car. HOWEVER, I AM NOT giving up yet. basically thinking of ALL my options. i could always pull the trans and take it completely apart, spend every spare minute researching the best parts to buy, and maybe have it together and in the car,,,,in 6 or 8 months. problem is, i need it for work, and i have done a lot of fixing it how i like it so i CAN'T let one issue make me quit.
Old 12-10-2012, 08:00 PM   #9 (permalink)
Maybe Nick or major know what years will swap into a 95 Vulcan ax4n. Or check the Hollander Interchange if you can access. Iirc, every salvage yard uses the Hollander.
Old 12-10-2012, 08:46 PM   #10 (permalink)
Taking Care of Business
04 SEL's Avatar
Member Number: 40467
Drives: 2004 SEL Duratec
04 SEL is a jewel in the rough
Huh. Wasn't aware that the AX4N was available before 1996. Interesting
Ben
2004 SEL, 60k miles, Vibrant White. 35% Tint, K&N Panel filter, Sylvania XtraVisions, Duralast CMAX, Remote Start, 4x Infinity Reference 6832cf, JVC KW-R800BT
04 SEL is online now   Reply With Quote
