Transmission Fluid Level Question - Taurus Car Club of America : Ford Taurus Forum
Old 12-05-2012, 10:50 AM   #1 (permalink)
Member Number: 28489
gandyj has a little shameless behaviour in the past
Default Transmission Fluid Level Question
2000 SEL 24 valve. After initial start up I put it in gear without applying any throttle there is a hesitation before car starts to move. If I apply throttle I get movement. I checked the fluid level cold and on level ground and the fluid was aprox. 3-5 inches above the hash marks. I checked it again hot and on level ground the fluid is between the hash marks. Why the initial hesitation and the difference in fluid levels? Are the two related?
Thanks
gandyj is offline   Reply With Quote
Old 12-05-2012, 11:19 AM   #2 (permalink)
sheila is just really nice
Atf should be checked with engine idling and at normal operating temp. Should be clean and red and in the safe crosshatch area. Mercon v atf. Fluid/filter change ea. 30k mi.
Old 12-05-2012, 04:01 PM   #3 (permalink)
Thank you, I understand the procedure for checking the fluid but what would cause the fluid to be 3-5 inches above the hash marks when cold?
Is this normal?
Old 12-05-2012, 04:21 PM   #4 (permalink)
intimidator's Avatar
Member Number: 18727
Drives: 12 SEL 201a 3.5
intimidator is an unknown quantity at this point
Is this normal?
Fluid has not yet been pumped through all of the valve bodies,passages and filter yet when cold. That is why you notice a higher level.
04 Taurus SES 3.0 Vulcan
03 Sable LS 3.0 Duratec
98 Contour Sport 2.5 Duratec
97 Lincoln Continental 4.6 Intech
70 Yamaha Twin 250
00 F-250 SuperDuty 4x4 6.8 v-10 Triton
12 Taurus SEL 3.5 Duratec FWD
intimidator is offline   Reply With Quote
