new taurus owner with problems - Taurus Car Club of America : Ford Taurus Forum
Old 11-18-2012, 04:17 PM   #1 (permalink)
Member Number: 51180
Drives: 95 taurus 3.0
taurus_3.OH is an unknown quantity at this point
Default new taurus owner with problems
Hi everyone ive just recently purchsed a 95 taurus gl 3.0 v6 106k orginal everything still works even the ac. anywho the car needed a tune up when i got it missed like and sob gave it a tune up does miss now while driving but the only thing is now it idles ruff and sometimes its will start and surge and shut off any ideas? thanks in advance
taurus_3.OH is offline   Reply With Quote
Old 11-18-2012, 04:38 PM   #2 (permalink)
The Page 93 Mastermind
TaurusDailyDriver's Avatar
Member Number: 42443
TaurusDailyDriver has a spectacular aura about
Haha I like your username. 3.OHHHH YEAH.
Anyways, seafoam may help you. It is good to use it to clean out the gunk.. namely carbon deposit buildup. When I do mine, I use the brake booster line to suck in a bit at a time and let it sit about 15 mins. Then I start it up and rev it.. cleaned out a lot for me. Smoother and lower idle afterward. My buddy's 01 Taurus stopped misfiring after seafoaming it the same way as well.
Paul T.
|2006 Taurus SE | Silver Frost |The 'Official' Bull of Central New York! | October 2012 COTM
|2005 Taurus SEL| Vibrant White | The Stock Bull
|1999 Taurus SE |
Toreador Red | Retired with 112k
TaurusDailyDriver is offline   Reply With Quote
Old 11-18-2012, 05:37 PM   #3 (permalink)
ok thanks for the reply and thats the only username i could think of i never owned a taurus before not really very knowledge on the 3.0s but i have owend alot of 4.0 rangers so im not sure there that much different. and another i think problem i have it is a bad motor mount but it in reverse its fine pull it into a forward gear and it like thumps not sure if it bad and the mounts bad well you know what i mean
Old 11-18-2012, 05:56 PM   #4 (permalink)
Ha it is all good! Anyways, so yes if you were interested in Seafoaming the car, I'd be more than happy to try to walk you through it. A very good process that shops charge a lot for to do.
It does sound like a mount *could* be going bad especially with the clunking. It may not happen in reverse just because of the low rate of speed. Does anything appear to be sagging, especially at an angle? And if you could have someone hit the gas while in park while you are observing when the hood is open to inspect the amount of movement.
Paul T.
|1999 Taurus SE |
Old 11-18-2012, 06:06 PM   #5 (permalink)
it doesnt really look to be sagging i havent had anybody pull it in gear with the brake on yet but ill have to. as far as the seafoam that will be a piece of cake. im pretty knowledgable on cars but it never hurts to be more knowledgable then i already am im not afriad to ask questions when it comes to a car that somebody has way more knowledge then me
Old 11-18-2012, 09:49 PM   #6 (permalink)
sheila is just really nice
Check for vacuum leaks. Clean/replace iac (idle air control).
Old 11-19-2012, 08:41 PM   #7 (permalink)
well guys i think ive found alot of my problem i out a fuel pressure tester on my taurus and it barely got to 20 psi so tomorrow it looks ill be doing a tank drop lucky me
