Member Number: 51186
Drives: 2005 3.0
i have an 2005 taurus i had the starter and fuel filter done about a year ago and the fuel pump done recently. my car is having problems starting , there is definitely power it was just turn over and wont catch. sometimes it will start right up but if i shut it off it wont work 1 minute later. could it be the crank sensor? im just having problems diagnosing the problem.
Member Number: 11378
Rep Power: 14 ![]() |
Does the CEL come on with key in RUN? If so, does the CEL go off when cranking? It it goes off, the crank sensor (CKP) is not the problem.
Have the battery load tested. 04+ are especially sensitive to low crank voltage.
![]() Member Number: 49890
I thought I replied to this when you posted it. If you have a scan tool that can check the fuel pressure, check it. It's possible you have a bad pump again. It does happen. Do the test that Jeff says though to see if its the CPK.
Drives: 2005 3.0
thanks for the replies,
the CEL does come on with key in run, and does go off when cranking. i will get the cel tested tommorow thanks again |
Drives: 2005 3.0
i had the cel tested and got the code PO420. what do you think the problem is?
#6 (permalink) | |
Cake monster
Member Number: 18214
Drives: none right now
It could be a bad oxygen sensor, or maybe a bad cat? I don't know much about that stuff.
That would be my guess. Either a bad O2 or bad Cat.... One thing I've heard people do is use a 93 octane or higher fuel and sometimes it helps get some crap burnt up. Heard seafoam works too. This seems like a bigger problem than starting problems...
A bad O2 sensor will not prevent the car from starting since they aren't used until the engine has warmed up. A bad catalytic convertor is a possibility only if it's blocking the exhaust. Does the car have normal amount of power when the engine is warmed up?
Like others have said, start by making sure the battery is good (load test the battery or try jumpstarting it). Otherwise the next thing I would check is the fuel pressure. Your fuel pump might not be working every time (they tend to cause intermittent no-start issues). |
