Speed sensor and metal shavings 99 24 valve OHC - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 11-12-2012, 11:50 AM Thread Starter
My 99 Taurus with 24 valve overhead cam was acting strange with the trany not shifting, speedometer failing, stumbling into gear at start and warning light for O/D OFF came on and off, one time it got stuck in a low gear. turning car on and off seemed to be a quick fix.
I bought a speed sensor from the junk yard and switched them. The one I took out had metal shavings on it. It is magnetic right?
All was working fine for 2000 miles or so, just saw the O/D OFF warning light and it stumbled at start a couple of times now.
Metal shavings cant be good.
Think the trany is ready to let go?
Is there any preventive action I could do?
Jerry56 is offline
post #2 of 8 (permalink) Old 11-12-2012, 12:15 PM
SoNic67's Avatar
Replace the fluid in the pan and the filter. Don't 'flush' it, just drain the pan, clean the magnet inside.
Then... wait.
SoNic67 is offline
post #3 of 8 (permalink) Old 11-12-2012, 12:20 PM
breeves002
Sam's Avatar
Year: 2008
Engine: 3.5L Ti-VCT V6
Trader Score: 8 reviews
If the magnet is full of metal that could be a bad sign, but do what sonic said. Drain the pan and clean the magnet. You can spray it out with a high flash point solvent like brake cleaner. If you don't have a magnet on there, get one.
2016 Ford Mustang GT Premium PP
2014 Ford Focus Electric
Moved On:
2008 Mercury Sable Premier
2000 Sable LS Premium Duratec
1997 Mercury Grand Marquis GS
Sam is offline
post #4 of 8 (permalink) Old 11-12-2012, 01:30 PM
SoNic67's Avatar
In the AX4N there is a circular magnet on bottom of the pan, sitting there stuck under it's magnetic force. It has even a round indent in the pan for the center hole.
Bad part is that there is no drain hole for the pan. It just leaks around the edge... start with the lower side bolts and put a oil pan there.
SoNic67 is offline
post #5 of 8 (permalink) Old 11-12-2012, 09:01 PM
Do the above and replace the salvage yard vss with a new one from a parts store. ~$20-25 for your ax4n tranny.
post #6 of 8 (permalink) Old 11-13-2012, 09:53 AM
I'll Be Watching You!
sousa632's Avatar
Model: Mercury Sable Wagon
Do what Sheila said. I would never put JY electrical parts as critical as a VSS in any of my cars.
John
2001 Sable LS Premium Wagon Duratec, 196K miles and kicking, 2013 Hyundai Sonata GLS
sousa632 is offline
post #7 of 8 (permalink) Old 11-13-2012, 04:13 PM Thread Starter
Thanks for the advice. I generally agree on the electric parts comment but i was there anyway getting a PS gear and for $3 now I know what the problem is.
Jerry56 is offline
post #8 of 8 (permalink) Old 04-07-2013, 09:59 AM Thread Starter
Over New Years I changed the tranny fluid, filter, cleaned the pan and that pan magnet was loaded with very fine material. Checked the VSS and there was no shavings on it.
Several thousand miles have passed, and no trouble since.
Jerry56 is offline
