Vacuum Lines - 2001 Duratec - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 17 (permalink) Old 11-25-2012, 06:26 PM
Purge valve looks like this:
behlinla is offline
post #12 of 17 (permalink) Old 01-03-2013, 06:40 PM Thread Starter
No Codes show up as such. I do occasionally have a Cyl 4 miss... but, that's another story I believe.
I glanced at the purge valve, and hoses are connected to it.
I need help with this !
Nobleserf is offline
post #13 of 17 (permalink) Old 01-03-2013, 06:54 PM
Did you count them to make sure all three are there? The loose hose should connect to one of the two larger barbs on the bottom.
behlinla is offline
post #14 of 17 (permalink) Old 01-08-2013, 06:15 PM Thread Starter
I went to the Ford Dealer... parts department... and glanced at the diagrams they had... and that was of no help.
This is driving me nuts. I can't believe I can't figure this out.
post #15 of 17 (permalink) Old 01-08-2013, 06:25 PM Thread Starter
behlinla ... the vacuum line running to the purge valve is connecting to the bottom of the intake. It seems fine. The loose vacuum line connects to the right of that... up a bit the side of the intake.
post #16 of 17 (permalink) Old 01-08-2013, 06:29 PM Thread Starter
more pics of the situation...
<br>
Here's some more pics of the scene...
my finger is pointing to the loose hose....
ID:	64796   Click image for larger version
ID:	64797   Click image for larger version
post #17 of 17 (permalink) Old 01-08-2013, 10:34 PM
Okay, let's try the EGR vacuum regulator (solenoid). It's bolted onto the passenger side of the intake and has a circular cap on it. There should be two vacuum hoses connected to the bottom.
Do you have EGR codes you're not telling us about? Make sure your check engine light works when you start your car.
behlinla is offline
