Loss of Compression in Cylinder #6 - Taurus Car Club of America : Ford Taurus Forum
post #1 of 3 (permalink) Old 11-21-2011, 07:52 AM Thread Starter
Lightbulb Loss of Compression in Cylinder #6
Hello Everyone, I took my car to the mechanic and he said we had loss of compression in #6 - which goes with the engine light error code of cylinder 6 misfires.
My car is just really weird. It will misfire with lots of loss of power after idling for a while (engine light also blinking then). then it will work fine. I can go 80 on the interstate (if the cops are not looking The idle is kind of rough and it smells like gas in the car.
So what exactly is going on in that cylinder? I am asking because I have to decide how much is a realistic price to fix it. Thinking of hiring someone from craigslist. The mechanic said it is probably a valve not sitting right, but i do not think he made a leak down test. Most of these private guys want to have the parts from me...and i want to make sure they are not pulling the wool over my eyes. Any ideas?
We thought it might have happened due to bad gas, the spark plug was fused together, really crazy.
BTW: 2002 Ford Taurus SE, V6 OHV, Automatic
acrobatman is offline
post #2 of 3 (permalink) Old 11-21-2011, 12:14 PM
Bigdogg2830's Avatar
well if you trust the mechanic that tested the cylinder then it might be a cracked ring, cracked head,bad head gasket or valves. i would do my own compression test. if it is low then add some oil to the cylinder and see if it improves. if it does then its the rings, if not its something else. it is possible the mechanic is lying, you do have a misfire and it might be a simple fix. plug, wire, coil.
Bigdogg2830 is offline
post #3 of 3 (permalink) Old 11-21-2011, 04:23 PM
What exactly does "lost compression" mean? Its down to 110 psi? 70 psi? zero psi?
DO not drive the car with a flashing CEL unless you want to spend $1000++ to replace the cats!
Jeff K is online now
