2001 Taurus misfiring in idle? - Page 2 - Taurus Car Club of America : Ford Taurus Forum
Old 08-22-2011, 02:12 PM   #11 (permalink)
Member Number: 38269
Drives: 2000 Taurus LX 3.0
daltomare is an unknown quantity at this point
Default Same Problem
I am currently having the same problem with my 2000 LX. I am getting code P0300. I actually stalled out a couple of times when sitting at a stop light. I was advised to change plugs and wires but I dont want to do this work and it be something else. Any suggestions? Or should I just stick with changing the plugs and wires. I also have been getting code P0457 and have changed the gas cap 3 times.
daltomare is offline   Reply With Quote
Old 01-16-2013, 09:49 PM   #12 (permalink)
Member Number: 13286
milehighassassin has a little shameless behaviour in the past
Getting the cylinder 1 misfire code as well. Random shaking at idle. I replaced all plugs and all wires. Still have the shaking. Have not been able to get the code to come up yet but haven't really ran it since it was shaking.
Could the coil be a problem on just 1 cylinder?
195k miles. Ran perfect until now, Owned since about 10k miles. Maintenance was done on time and properly.
I was thinking coil next but if it is more serious I don't want to throw more money at this.
I suppose a compression test would say for sure. Kinda a pain to get to the 1-3 cylinders. What fuse # to pull to kill the injectors/fuel pump?
TIA
milehighassassin is offline   Reply With Quote
Old 01-16-2013, 10:15 PM   #13 (permalink)
sheila is just really nice
Yes, a faulty coil can cause a single cylinder misfire. Check the cyl. drop test video on here. You can also run primary and secondary resistance tests on the coil.
