Hard Shift In Transmission - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 03-08-2010, 11:41 AM Thread Starter
96 Taurus Wagon, 80 K miles, OHV
Very hard shift from 1st to 2nd gear. Other then that car runs great. Any one? Thanks
johnT is offline
post #2 of 11 (permalink) Old 03-09-2010, 12:06 AM
qwertz9586's Avatar
Change the trans fluid and filter. It could be a bad VSS if you're also having cruise control and speedometer issues. Other than that I'd live with it.
qwertz9586 is offline
post #3 of 11 (permalink) Old 03-10-2010, 02:12 AM
I'd try the general service proceedure's mentioned, but don't recommend living with it. The final drive gear's in these transaxles are pretty weak, and wont stand up to much shock. Skipping a few hundred buck's of repair's, could end up costing you a lot more.
Borbet225 is offline
post #4 of 11 (permalink) Old 03-13-2010, 12:52 PM Thread Starter
QUOTE (Sable98W @ Mar 10 2010, 03:12 AM)
I'd try the general service proceedure's mentioned, but don't recommend living with it. The final drive gear's in these transaxles are pretty weak, and wont stand up to much shock. Skipping a few hundred buck's of repair's, could end up costing you a lot more.[/b]
Changed the trans oil, but jolt from 1st to 2nd is still there. Beside this, car runs great with no issue at all.
johnT is offline
post #5 of 11 (permalink) Old 03-31-2010, 03:40 PM
im actually having the same problem - im about to try replacing the tps, since a couple other guys did the same thing to relieve their hard shifts...
"Nom-de-plume: when a yard gnome explodes"
coldspit47 is offline
post #6 of 11 (permalink) Old 03-31-2010, 06:13 PM
Okay one quick suggestion by me. In doing any of this, have either of you reset the transmission computer? This entails a simple taking off the battery for a few minutes and then putting it back on. I suggest this because the transmission learns how you drive, with its shift points and such. With a reset of the computer it will relearn and sometimes get rid of that clunky shift that could be caused from harder driving switching to easier driving. The Gen 3 and Gen 4 I'm positive learn but the gen 2 I'm not sure of, any one else wanna chime in for me that would be great!
Gentz is offline
post #7 of 11 (permalink) Old 03-31-2010, 07:27 PM
QUOTE (Gentz @ Mar 31 2010, 06:13 PM)
Okay one quick suggestion by me. In doing any of this, have either of you reset the transmission computer? This entails a simple taking off the battery for a few minutes and then putting it back on. I suggest this because the transmission learns how you drive, with its shift points and such. With a reset of the computer it will relearn and sometimes get rid of that clunky shift that could be caused from harder driving switching to easier driving. The Gen 3 and Gen 4 I'm positive learn but the gen 2 I'm not sure of, any one else wanna chime in for me that would be great! [/b]
(94 taurus 3.0l v6) - i tried that and left the battery disconnected for about an hour to completely stupefy the computer, then reconnected them...in fact, after i did that, it drove better than when i got it...but only for a little while...then it went right back to hard shifting and barkin the tires
post #8 of 11 (permalink) Old 03-31-2010, 07:34 PM
daveromanjr's Avatar
Send a message via AIM to daveromanjr
QUOTE (coldspit47 @ Mar 31 2010, 07:27 PM)
I'd still recommend that for the 96, give it a whirl and see how it comes about.
The 94, however, I'm not sure if it has the "learning" transmission. With your scenario I'd definitely think a flush is in order. The tranny's 1-2 shift can be amazing hard even in the lightest of conditions, just keep that in mind if you do get a flush as it won't be silky smooth, unfortunately.
daveromanjr is offline
post #9 of 11 (permalink) Old 04-01-2010, 07:22 PM
mine has the learning computer - but you have to leave the battery disconnected for at least an hour...and it takes ~50 miles for it to completely relearn its points...im kinda afraid to flush the tranny since i dont think its ever been done - so i dont want to put brand new slick tranny fluid in when it goofs a bit already...
post #10 of 11 (permalink) Old 07-04-2012, 11:45 PM
I found this discussion because I'm also having a hard shift in my 01 Taurus from first to second. I also noticed last week that the cruise control no longer works. I had the transmission flushed about a month ago and although that seemed to help for about two days, the hard shifting returned. The car seems to run fine once it's in gear - gets up to 80 MPH no problem and runs smooth - but it shifts hard.
I've seen the VSS referred to earlier in this discussion. Would that be a likely starting point?
goon is offline
