Old 03-04-2010, 12:54 PM   #1 (permalink)
Dubeckyj's Avatar
Member Number: 19977
Dubeckyj is an unknown quantity at this point
Alright, so to accompany my composite UIM that's going on, I've got a 60mm throttle body and whatever size MAF off a '96 'tec. The throttle linkages look like they'll go on without a problem. Along with the MAF, I kept it on the top half of the intake box, and it looks like it'll fit right into my lower. The IAT is housed in the air box, so I might have to extend the wires but that's covered. The MAF plug is the same, so that's fine. The tube from the MAF to the TB has three vacuum connections, whereas the tube on my '97 vulcan only has two. I don't know what the third one is for, but I'm thinking I'll just seal it off. I don't know about electrically, but physically, it's completely plug & play. Am I forgetting about anything, here?
Dubeckyj is offline   Reply With Quote
Old 03-04-2010, 01:08 PM   #2 (permalink)
ffvulcanpowah's Avatar
Member Number: 2120
Drives: 2000 Taurus SE / 3.0 Vulcan FFV / AX4Stupid
ffvulcanpowah is an unknown quantity at this point
Send a message via AIM to ffvulcanpowah
You'll need the airbox top from a Duratec. The bolt holes in the vulcan airbox are too close together to fit the 'tec maf. IF the car idles with the swapped duratec maf, chances are, it will run like poo. This swap is not the best idea without proper tuning to accomodate the larger MAF size.
The throttle linkage on the duratec TB should be different than your vulcan's. I had to swap cables when I used the g3 Tec TB on my vulcan. It's not a hard swap, just a bit of a pain to remove from the donor car.
You'll need an adapter or a good way to seal the 'tec tb to the vulcan intake manifold. The bolt pattern is the same, but that's where the exact similarities end. The IAT tunnel is positioned differently, and the opening in the vulcan UIM is smaller than the exit of the 'tec TB. The exit of the 'tec tb is larger than the rubber o-ring seal on the composite manifold.
You'll also need to flip the TPS around. In it's stock, rear-facing position on the 'tec TB, you'll encounter interference with the brake booster line on the composite manifold. When flipped (i/e in the positon that the vulcan TB has it in), there are no interference problems.
Physically, the MAF is a bolt-on project (with appropriate parts). The throttle body is not a straight bolt-on project when being attached to a vulcan intake manifold, but it IS possible.
"YOU WILL ALL BOW DOWN TO MY AWESOME SHO THAT IS REALLY JUST A TAURUS WITH FIDDLY BITS AND TWO MORE CYLINDERS!!!11ONE" -Dan
"If you got the lack of sense to mod a TAURUS you should be allowed to cut a hole in your hood. Let everyone see the extent of your madness" -Luke
ffvulcanpowah is offline   Reply With Quote
Old 03-04-2010, 01:34 PM   #3 (permalink)
Dubeckyj's Avatar
QUOTE (FFVulcanPowah @ Mar 4 2010, 03:08 PM)
Physically, the MAF is a bolt-on project (with appropriate parts). The throttle body is not a straight bolt-on project when being attached to a vulcan intake manifold, but it IS possible.[/b]
Yeah, I read your topic about the TB swap, so I'm still looking for aluminum to do the adapter plate. I'm just having trouble getting the screws off of the TPS to turn it around without stripping them. I have the top of the duratec airbox, it's still attached to the MAF. I guess I'll wait to do this mod 'till I have an SCT tuner, then.
EDIT
Actually, why does it have to be aluminum? What happens if I use regular steel for the adapter plate, or even plastic?
Old 03-10-2010, 09:42 PM   #4 (permalink)
94clit's Avatar
Member Number: 3992
94clit is an unknown quantity at this point
Send a message via ICQ to 94clit Send a message via AIM to 94clit
You could make it out of whatever you want.
i would like to personally thank volvo! garage
94clit is offline   Reply With Quote
Old 03-11-2010, 12:25 AM   #5 (permalink)
Member Number: 2120
I chose aluminum because It's light, won't corrode easily, and was decently easy to work with.
You could use steel. It's just heavy, takes a lot more to machine (unless you have access to machining equipment), and is prone to corrosion/rust.
A thick piece of plastic that is able to withstand higher temperatures, and wont react to oil would work, too. Perhaps what folks make phenolic spacers from.
So yeah, aluminum is just a suggestion.
Old 03-11-2010, 08:14 AM   #6 (permalink)
Dubeckyj's Avatar
I made it out of some composite I found for $25. I was going to take some pics, but I'm pretty embarrassed of my shoddy workmanship on it. It took way too long for me to cut another piece and try again, though. It doesn't look pretty but it'll do its job.
I'm going to be grabbing a throttle cable for the 'tec this afternoon, and I'm waiting on an EGR tube still (my dealer had to order it in) so this swap won't be done for another week or so. In the meantime, should I place some of the leftover plastic in a bin of dirty oil and see if it corrodes? I have no idea what kind of material it is.
Old 03-11-2010, 09:37 AM   #7 (permalink)
Member Number: 2120
Couldn't hurt.
You'll likely hit a snag when you try to fit up the EGR tube. The rear exhaust manifolds between the g3 and g4 are different, including where the tube attaches to the exhaust manifold. IF it works, that would be most excellent, but I foresee it being a cut and paste affair.
Old 03-11-2010, 09:45 AM   #8 (permalink)
Dubeckyj's Avatar
QUOTE (FFVulcanPowah @ Mar 11 2010, 10:37 AM)
Couldn't hurt.
You'll likely hit a snag when you try to fit up the EGR tube. The rear exhaust manifolds between the g3 and g4 are different, including where the tube attaches to the exhaust manifold. IF it works, that would be most excellent, but I foresee it being a cut and paste affair.[/b]
Yeah, I've read the UIM swap topics. I'm going to try heating it first to see if it can be bent into place. Failing that, I'll be borrowing my neighbor's welder.
And I got one of the bolts out of the TPS. The other one is way too stripped. I'm going to try to cut a slot into it and try a different bit, but I'll probably end up drilling it out.
Old 03-11-2010, 11:07 AM   #9 (permalink)
TCCA Technical Advisor
Member Number: 125
shoz123 is an unknown quantity at this point
To accurately tune the MAF you will need a Wide Band O2 sensor.
Old 03-11-2010, 11:44 AM   #10 (permalink)
Dubeckyj's Avatar
QUOTE (SHOZ123 @ Mar 11 2010, 12:07 PM)
To accurately tune the MAF you will need a Wide Band O2 sensor.[/b]
Why's that?
And I got the throttle cable. It was tough to get to, I ended up ripping off the UIM from the donor car so I could get to the housing bolts. And I stepped in a puddle. It was a most uncomfortable experience.
