Old 03-11-2010, 11:48 AM   #11 (permalink)
TCCA Technical Advisor
Member Number: 125
shoz123 is an unknown quantity at this point
Because that is the only way to accurately calibrate the MAF in a tune.
Old 03-11-2010, 12:08 PM   #12 (permalink)
Dubeckyj's Avatar
Member Number: 19977
Drives: 1997 Mercury Sable GS
Dubeckyj is an unknown quantity at this point
Is the actual sensor different entirely, or is it that it'll meter the air at a different ratio than a smaller diameter MAF?
Dubeckyj is offline   Reply With Quote
Old 03-17-2010, 01:51 PM   #13 (permalink)
Dubeckyj's Avatar
UPDATE: I got the composite UIM and 'tec TB and MAF on yesterday. I cut out the brace from my vulcan's MAF last spring (with no issues) and looking at them side-by-side, they probably flow about the same amount of air, maybe even less for the duratec. It idles a bit high, but other than that, no problems. I'll post pics later, and maybe a vid if i can find a videocam.
Old 03-18-2010, 01:06 PM   #14 (permalink)
ffvulcanpowah's Avatar
Member Number: 2120
Drives: 2000 Taurus SE / 3.0 Vulcan FFV / AX4Stupid
ffvulcanpowah is an unknown quantity at this point
Send a message via AIM to ffvulcanpowah
Odd... If everything is sealed up correctly, it should idle the same as stock.
"YOU WILL ALL BOW DOWN TO MY AWESOME SHO THAT IS REALLY JUST A TAURUS WITH FIDDLY BITS AND TWO MORE CYLINDERS!!!11ONE" -Dan
"If you got the lack of sense to mod a TAURUS you should be allowed to cut a hole in your hood. Let everyone see the extent of your madness" -Luke
ffvulcanpowah is offline   Reply With Quote
Old 03-18-2010, 08:48 PM   #15 (permalink)
Dubeckyj's Avatar
QUOTE (FFVulcanPowah @ Mar 18 2010, 02:06 PM)
Odd... If everything is sealed up correctly, it should idle the same as stock.[/b]
While bolting everything together, the TB looked to have some sort of air passage on it behind the throttle plate that flows air in from outside the TB. Is this supposed to be there? Should I plug it up with something? I thought unmetered air was bad, and it might explain the high idle.
