Trouble Codes: P0446, P1260, P1450 - Taurus Car Club of America : Ford Taurus Forum
post #1 of 3 (permalink) Old 06-04-2006, 01:04 PM Thread Starter
I got my first SES codes on my 97' Sho on my way home from my girlfriends house this morning. I pulled them with my X-Cal II as soon as I got home and found P0446 (Evaporative Emission Control System Vent Control Circuit), P1260 (Fuel and Air Metering), and P1450 (Auxiliary Emission Controls). Ok, so I still don't know what the hell all of that means. Oh, I am currently running the 87 oct tune on my X-Cal II. I cleared the codes and shall await their return.
97 ES Sho-modded-82K
98 BC Sho-modded-82K
ict_Lx is offline
post #2 of 3 (permalink) Old 06-04-2006, 04:05 PM
HX18 DTC P0446 OR P1450: CHECK FOR VISUAL CAUSES OF EXCESSIVE FUEL TANK VACUUM
Continuous Memory Diagnostic Trouble Code (DTC) P0446 or P1450 indicates that Self-Test has detected the Evaporative Emission Control System has excessive fuel tank vacuum. Also, a DTC P0446 indicates a vent control malfunction.
Possible causes:
EVAP canister purge outlet tube (EVAP canister purge valve to EVAP canister) blockages or kinks.
EVAP canister tube (fuel tank to EVAP canister) blockages or kinks.
Fuel vapor elbow on EVAP canister contaminated.
Restricted EVAP canister.
Canister vent (CV) solenoid stuck closed (partially or fully).
Plugged or contaminated CV solenoid filter.
EVAP canister purge valve stuck open.
Fuel filler cap stuck closed (no vacuum relief).
VREF circuit open in fuel tank pressure (FTP) sensor.
Damaged FTP sensor.
Note: If the EVAP canister-CV solenoid and fuel tank assemblies are not accessible to perform the following step, GO to the Powertrain/Engine Group, Evaporative Emissions Section in the Workshop Manual for removal procedures.
Check for kinks or bends in the fuel vapor hoses/tubes (EVAP canister purge outlet tube and EVAP canister tube).
Visually inspect EVAP canister inlet port, CV solenoid filter and canister vent hose assembly for contamination or debris.
Check CV solenoid filter for blockage or contamination.
DTC 1260 is a PATS code but the manual says to fix all other DTCs before worrying about a 1260.
post #3 of 3 (permalink) Old 06-04-2006, 05:12 PM Thread Starter
Possible causes:
Damaged FTP sensor.
Thanks...that sure is alot to check for those two codes. I figured the P0446 and P1450 were related though. <_<
ict_Lx is offline
