Dashboard !brake! Light Is On.... - Taurus Car Club of America : Ford Taurus Forum
post #1 of 12 (permalink) Old 04-25-2005, 05:35 PM Thread Starter
Thumbs up
Hi all,
Since I am a noob to the Taurus Forum (a second gear member of Miata.net), please go easy on me. I just purchased a 98 Taurus SE wagon. It only has 54k miles on the clock. Everything seems to be in good working order. However, the red BRAKE light on the dash is on, like when the parking brake is set. I have pulled on the e-brake handle several times, and it is not engaged. The brake fluid level is a little below MAX, but not too low. The brakes feel fine, but the light never goes off. Is there a 'sensor' on the e-brake that can go bad? Or, can the brake cable stretch to make this happen? Any and all help would be appreciated!
Thanks,
Richard
p.s. I read in the FAQ section that all 96-98 4 wheel disc brake cars had ABS. Is this true?
Thanks,
Richard
1998 Ford Taurus SE Comfort Wagon (Moby)
2004 Toyota Sienna XLE (The Nimitz)
1992 Mazda Miata (the Red GOOGAH)
CaptainMiata is offline
post #2 of 12 (permalink) Old 04-25-2005, 07:43 PM
There is a sensor on the ebrake for the light... I've seen this happen on numerous makes and models.
My Taurus is the opposite.... sometimes the break light never lights up when I engage it...
I'm not sure what type of switch it is...but if you spray some tuner or contact cleaner into it, the problem should be solved.
And yes, as far as I know if you have 4 wheel discs, you have abs...
Current Vehicals:
1998 Volvo V70 AWD 196,000 (project)
1998 Volvo S70 T5 206,000 (daily driver)
1996 Ford Taurus LX 187,000 (rusted out, but drives)
1980 Mazda RX-7 Anniversary X 142k (project)
Past Vehicals
1993 Isuzu Trooper (junked)
1992 Ford Tempo GL (sold)
1992 Subaru Loyale (sold/junked)
1994 Toyota Camry LE (sold)
1996 Ford Taurus GL (junked)
1994 Ford Aerostar Cargo (sold)
1993 Ford Taurus (traded)
1990 Ford Tempo GL (sold/junked)
1987 Dodge Aries (junked)
tmonster is offline
post #3 of 12 (permalink) Old 04-25-2005, 07:49 PM
qwertz9586's Avatar
Just clean the e-brake switch with WD-40 or some rubbing alcohol. Also might wanna check your pads.
qwertz9586 is offline
post #4 of 12 (permalink) Old 04-25-2005, 07:50 PM
Send a message via AIM to sixfofalcon
When the parking brake pedal is let all the way up, it strikes a switch. Sometimes things get misaligned and the switch doesn't get pushed in. This happened to me when I moved my battery to the trunk, and the switch was moved to the side just a tiny bit.
Philadelphia, PA
TOTALED1997 Ford Taurus SHO - 3.4L 32V Yamaha V8 - 90K - Kirked at 58K, 24mm FSB, 25mm RSB, Ford rear SFBs all around, Bob Gervais FSTB, VAK, K&N panel, SARC cutout switch, butterflies gutted, Apten performance chip, trunk-mounted dual Odyssey PC625s
TOTALED1995 Ford Taurus GL - Vulcan+AX4N - 91K - some mods
1964 Ford Falcon - 154K - 200 CID inline six, MSD 6AL + Pertronix, Granada discs
sixfofalcon is offline
post #5 of 12 (permalink) Old 04-26-2005, 10:27 AM Thread Starter
Thanks for your help, everyone! I really appreciate it, and will check that contact this afternoon!
Thanks again,
Richard
Thanks,
Richard
post #6 of 12 (permalink) Old 04-26-2005, 10:32 AM
My old Topaz did this when there was no material left on my pads. Check them and make sure the backing plate isn't contacting the rotor.
JR
godspunk32 is offline
post #7 of 12 (permalink) Old 04-26-2005, 10:46 AM
If the pedal doesn't return all the way up fully, the light won't go out. Push the pedal up with your foot, if the light goes out, the switch is worn or the cable will need to be adjusted.
2002 Chrysler 300M Special - 1968 Mustang Fastback - 1994 Subaru Legacy 5-sp.
ex-1995 MTX SHO - ex-1993 Vulcan GL
TrueBlue is offline
post #8 of 12 (permalink) Old 04-26-2005, 11:12 AM
they scews that hold the switch to the park break can back off and let the switch rotate away from the pedal. causing the light to stay on.
2000 Duratec SE White Wagon
crackhead is offline
post #9 of 12 (permalink) Old 04-26-2005, 01:10 PM
Check you fluid level in the MC. If it is low then your pads are worn down and you need new one.
post #10 of 12 (permalink) Old 04-26-2005, 04:37 PM Thread Starter
Update: I checked under the dash at lunch, and I saw the switch you guys told me about. I pushed the switch, but the light stayed on. It looks like there is some rubber on the top of the brake contact part that has rubbed off, but the switch should cut off if I push it in, shouldn&#39;t it? I will try some contact lube.
Thanks,
Richard
p.s. Here is a photo of Moby!
Thanks,
Richard
