Member Number: 4908
ok, heres another really weird one. got this surge while cruising, rpm's will noticably surge 200-300 on the tach, and i can feel it in the car. not sure if its in the tranny. also, on medium to hard acceleration, she will surge and then smooth out and when it smooths out, its like this sudden burst of power. either something in the tranny is slipping, (bad press solenoid?/clutches?), or maybe a worn timing chain? this is evident in all gears also, and when parked on an incline the tranny grumbles a bit. i got on it from a stop today, and all the shifts were firm and right on, but its like she wasnt pulling as hard as she could(surging)until 4000 rpms. then she wound up quick and painless. it idles like a champ except for a noticable popping sound from the intake and it doesnt seem to be missing. fresh plugs, wires,fuel filter, fuel press regulator and coil pack so who knows. why does my car have the weird problems?
97 Taurus GL 'THE WILLOW GREEN STREET MACHINE' 3.0 OHV, AX4N Trans, Mods.-air intake silencer removed, Cyber White foglamps, Black Fuzzy Dice on the rear view mirror. Future Mods/Projects-home brew intake, CD player,SHO spoiler. 155,000 miles and counting....... |
Member Number: 125
That is the TC locking and unlocking.
Paul Nimz '10 Red Genesis Coupe '08 Hyundai Accent |
Member Number: 4908
is that normal?
Member Number: 125
Normal for Ford programming. You will notice that if the climate control is in a non-AC state such as floor or vent only that it will not do this.
It takes a chip to program it out. Really dumb idea because it causes excess wear on the TC clutch and heats up the fluid. But maybe that is Ford's plan?????
Member Number: 4863
Any comments on this? Very similar-sounding thing:
I have an '02 with the Vulcan, 37K. I have been suspicious of my transmission too. I'll explain this scenario as though I'm accelerating gently and steadily because I know the numbers better: From a dead stop, shift 1-2 at about 15mph. Keep going; shift 2-3 at about 25mph. Once I hit about 33-35mph, I also get a little surge and the tach drops about 200-300 RPM from around 2500RPM. Then usually immediately afterward in the 35-37mph range, I get the final kick down to around 1500 RPM. It's almost like 4 shifts? What is up with that? Which of those final 2 bumps is the TC? *Edit* This is with a/c off. |
Member Number: 1637
have you tried unhooking the battery for an hour.. I do it overnight. Drive like you want it to be driven and it will adapt to your driving style.....
Current Vehicals: 1998 Volvo V70 AWD T5 Conversion 196,000 1993 Isuzu Trooper 192,000 1998 Volvo S70 T5 140,000 1992 Ford Tempo GL 68000 1996 Ford Taurus LX 178,000 1980 Mazda RX-7 Anniversary X 142k Past Vehicals 1992 Subaru Loyale 1994 Toyota Camry LE Junk. 1996 Ford Taurus GL 1994 Ford Aerostar Cargo 1993 Ford Taurus 1990 Ford Tempo GL 1987 Dodge Aries |
#7 (permalink) | |
Member Number: 4863
![]() The car was driven I presume mostly by the same person up until 35K when I got it. So another question is, to what extent is the car unable to adapt? What I mean is, if somebody drives the car from fresh keepalive memory for 35K, then I get in it and drive it for 2000 miles, how different is its current state than it would be if I just started fresh? I know these kinds of things are a mystery for a lot of people and I've been doing as much research as I can find online, but sometimes it's hard because it's even tough for Ford techs because I just think even Ford doesn't completely disclose that info to them. |
#8 (permalink) | |
Member Number: 125
It is hard to feel the 3rd unlocked/locked transition but it can be seen with data monitoring software. It is also rumored that it happens in second also but I have not seen it happen. With the Auto Tap software I can see the amount of slip that is across the TC clutch. When it is locked there is usually 0 to 5 rpm slip. On the V8 SHO you will feel a real change at WOT when the TC locks up in 3rd which is usually around 80 mph or so. Ideally when you accelerate, after up shifting or down shifting and after a slight pause you want the TC locked. This also is what gives very little engine braking when you first let up on the gas while cruising. At this time the TC is slipping and will after a while lockup to get real engine braking.
#9 (permalink) | |
Member Number: 4863
So that small bump that drops from about 2500 to 2200, that's the TC locking in 3rd? Or is it the 3locked to 4unlocked shift? Likewise, is the 2200->1500 drop the 3rdlocked->4unlocked or 4unlocked->4locked? I really appreciate this. This is my first automatic transmission! (*sigh*) |
#10 (permalink) |
Member Number: 125
When the TC locks it will drop the rpm about 300, when it unlocks it will raise the rpm about 300 rpm.
