Soft Brake Pedal - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 10-27-2004, 12:13 PM Thread Starter
GTM
Send a message via MSN to GTM
Thumbs down
When I hit my brake pedal....the brake works fine and everything.....as a matter of fact I just installed new rotors and pads, but it's soft as in, it's not as responsive as other brakes (CV, Escape, Focus etc) and I have driven all of those cars....this problem has been there for a long time (can't remember if it was there when I first got the car)
Help me if you can..
Taurus '98 SE w/ V6 3.0 Vulcan
~pretty much all stock for now except:
*Pioneer 6-CD changer.
Future mods:
*Flowmaster muffler.
*K&N air filter.
*Moog TPR bushings
GTM is offline
post #2 of 6 (permalink) Old 10-27-2004, 01:12 PM
Tell us what you used for replacement?
2000 SES Vulcan
Intake Silencer Removed
FullDuplex is offline
post #3 of 6 (permalink) Old 10-27-2004, 01:49 PM
Might try changing the brake fluid (bleed the brakes)
Current Ride: 2004 Chevrolet Impala SS Indianapolis Motor Speedway Edition - #1752 of 4088
-3.8L SC Engine - 240 hp, 270 tq, 87,000 miles
- PFC front pads|Silverstar Ultra Headlights & High Beams|K&N CAI|Optima Redtop Battery|17"x7.5" Sort Edition F7 Rims|Kumho Escta SPT Tires
Old Ride: 1998 Taurus SE Sport with the Duratec 122k miles - October 2006 COTM
K&N Filter|JVC KD-G300|2 10" Lightning Audio Subs|450W Lightning Audio Amp|Silverstars|PFC Pads, Duralast Rotors (Rear)|EBC Greenstuff Pads and Duralast Rotors (Front)|Hadyen Tranny Cooler|Pioneer 2-way 6"x8" Speakers|Polk Aduio 6.5" components|KYBs w/ SHO Springs|23mm Rear Swaybar|Gen III SHO Wheels w/ Ponteza G009s|SFCs|FSTB|SHO Bros High Flow Y-pipe
EDIII is offline
post #4 of 6 (permalink) Old 10-27-2004, 01:55 PM
jason8225
Guest
Posts: n/a
I had this problem and got my fluid flushed and replaced with Valvoline Synthetic Fluid - never felt better!
moving to maintenance and repair...
post #5 of 6 (permalink) Old 10-27-2004, 03:32 PM
You have moisture and air in your brake fluid. You should completely change your brake fluid every two years. I recommend Valvoline SynPower Brake Fluid, because it's readily available, not expensive, meets Ford's HBH requirements, and because of its high wet and dry boiling points. For street use, pay particular attention to the wet boiling point; accordingly, DOT 4 and DOT 5.1 are the fluids of choice. Read my pinned article.
topgunovrtx is offline
post #6 of 6 (permalink) Old 10-28-2004, 03:42 AM Thread Starter
GTM
Post
Thanks for the help guys, I kind of always knew that was the problem, but I have bleeded the fluid last year and put some motorcraft DOT3.....well I guess I'll try to find the Valvoline Synpower stuff at the autoshops today.
Future mods:
*K&N air filter.
*Moog TPR bushings
GTM is offline
