squeaky noise from passenger side for 2000 Taurus OHV - Taurus Car Club of America : Ford Taurus Forum
post #1 of 7 (permalink) Old 02-16-2017, 10:28 AM Thread Starter
Year: 2000
Hello all,
I saw the same issue as shown on this video for my car(2000 Ford Taurus OHV)
I need to replace the Serpentine Belt. What is the correct part number for this one?
Based on RockAuto, I found the part number MOTORCRAFT JK6861AC. But it is shown as Air Conditioning V-Belt.
Q1> Is this correct part for the Serpentine Belt?
Q2> I have never replaced the belt myself before. Is there anything I need to pay attention while replace the belt?
Thank you
q0987 is offline
post #2 of 7 (permalink) Old 02-16-2017, 10:56 AM
Squeak could also be from the tensioner pulley, a bad bearing in the alternator, AC clutch bearing, etc. I would pick up a mechanics stethoscope from HF for under $5 and hunt for the source of the squeak.
Replacing the belt on a Vulcan is a 5 minute job.
Jeff K is online now
post #3 of 7 (permalink) Old 02-16-2017, 11:02 AM Thread Starter
Year: 2000
Hello Jeff,
Thank you for your info.
The noise goes away after the car is started for 2-3 minutes, so I assume the issue is related to the belt. The current belt has been running for around 50K miles and it is time to replace anyway. I will check all the parts while when I replace the belt.
Thank you
q0987 is offline
post #4 of 7 (permalink) Old 02-16-2017, 11:41 AM
Could be a weak tensioner and once the alternator load drops from car starting the belt stops squeaking.
Automender12345 is online now
post #5 of 7 (permalink) Old 02-16-2017, 11:45 AM
Year: 2000
I think 15mm on tensioner to loosen tension. Need anlong wrench or serpentine toool. Not much room. Make note of routing. Pull back fender splashing to put new one on around harmonic puller. Again not a whole lotta room but doable
shawnjhawn is offline
post #6 of 7 (permalink) Old 02-16-2017, 11:51 AM
I'd recommend the Continental Elite (formerly named Goodyear Gatorback) serpentine belt from Rockauto. #4060855 for $24.79. I realize it's twice the price of the Motorcraft, but silence is golden, lol.
post #7 of 7 (permalink) Old 02-16-2017, 12:18 PM Thread Starter
Year: 2000
Hello Automender12345,
Most of the time, the squeaking only happens the first time the car is started during the day.
For example, if I start&drive the car in the morning, I will hear the noise. Later, if I start&drive the car again, the noise doesn't happen.
I have ordered the part from RockAuto and will report back with my findings.
Thank you all!
q0987 is offline
2005 Taurus slow washer fluid stream on driver's side (again) Annorax Maintenance and Repair 5 06-13-2016 07:32 PM
1998 Taurus - 12 valve OHV AC low side is low, high side is low fabsroman Maintenance and Repair 2 06-07-2015 10:31 AM
2000 dohc taurus p1237 and rattling noise hight24 Maintenance and Repair 7 09-30-2014 12:05 AM
Passenger Side Vent Removal And Creak Fix redhousenine Aesthetics, Interior, Wheels and Tires 2 04-17-2013 10:57 PM
Creaking Passenger Side Vent - A Solution redhousenine Aesthetics, Interior, Wheels and Tires 0 10-06-2012 10:04 PM
