Daughters car is running me nuts - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By Automender12345
post #1 of 10 (permalink) Old 02-13-2017, 11:46 AM Thread Starter
My daughters car. 2006 Taurus, Vulcan engine, 3.0, 70,000 miles.
The engine light came on and she continued to drive it. Had to tow it home. It had melted a hole in the intake plenum. Had a bank 2 cat code on it. I replaced the plenum. The pcv connector had melted as well as a vacuum tube above the plenum. I was ordering parts so I replaced the pcv valve and the mas also.Also replaced plugs and wires and put new valve cover gaskets on(found a small leak) while I had the plenum off. Probably didn`t need to but they were cheap enough.The lower oxygen sensor was damaged so I replaced it. Did a test on the cat with an IR thermometer and it was OK. Was idling fine but took a little extra to start. Checked for vacuum leaks with carb cleaner, found none so I smoke tested for leaks . Smoke from egr valve ports but nowhere else. Turned the key on and saw no smoke at all and couldn`t hardly blow in the vacuum tube at all. Also tested the brake booster for leaks. Found nothing.
Cleared the code and took it for a drive. Ran like crap , turned around and came home. Showing lean codes on both banks. Replaced fuel filter and tested fuel pressure on the engine side of the fuel filter. There is no port for testing on the fuel rail that I could find. Initial pressure after the fuel filter is about 50 pounds.After cranking it drops to about 35 pounds at idle. Put in some sea foam to try to clear injectors if they were clogged.
Car cranks good, idles good with no missing. So I cleared the codes and took it out again. Car has some lack of power and has a small almost undetectable miss or surge after about 40 mph. . And when I stepped down on the gas to engage passing gear it just revs up to 3500 rpm and won`t shift at all.Doesn`t matter if I`m going 30 or 50 at the time. If I don`t step down on the gas it shifts.Windows and other electronics work. I drove it about five miles or so and it hasn`t thrown any other codes at all. Lean codes and cat codes are gone for now. I haven`t changed the transmission fluid or filter yet but this seems like something else to me.I will clean the egr in case it stuck open and melted the plenum before I give it back to her. But this shifting thing and lack of power has me stumped. I hope someone knows what it is. I`m to old for all this stress. Thanks
tinytim is offline
post #2 of 10 (permalink) Old 02-13-2017, 03:03 PM
Sounds like plugged cats may be your problem. That would have caused excessive EGR flow and melted your intake. My 2006 has slightly heat damaged intake at the EGR inlet area without cats that could be plugged.
Automender12345 is online now
post #3 of 10 (permalink) Old 02-13-2017, 05:12 PM Thread Starter
I thought so too
From what everyone said, that was my thought at first. Because of the melting. I read that the temp in front of the converter would be quite a bit different from the back. If it was cooler in the back it would be plugged up. My temp was running about 50 to 100 degrees higher behind the converter depending on where I tested. The oxygen sensor was bent when I took it out and looked about 100 years old so I replaced it. After replacing damaged stuff the code for the converter didn`t come back. I used a mallet on the converter to listen for rattling also. I didn`t hear any.It seems odd to me that the car won`t shift if given a lot of gas but shifts if I go easy on the gas.It`s undrivable as it is.
tinytim is offline
post #4 of 10 (permalink) Old 02-13-2017, 05:31 PM
disconnect one of the hoses from the DPFE sensor and put a pressure gauge in there. If the pressure goes up then you have a plugged exhaust and/or catalytic converter (it should not go above 1psi). if you think your cat is fine, remove the post-cat oxygen sensor and put your pressure gauge there.
and
and
lincolnshibuya is offline
post #5 of 10 (permalink) Old 02-16-2017, 05:28 PM Thread Starter
Cats not stopped up
Took off the cats today. Believe me they are not stopped up. In fact there is nothing in there. They have been emptied out already .
tinytim is offline
post #6 of 10 (permalink) Old 02-16-2017, 06:04 PM
You should have been getting some cat efficiency codes on the PCM then.
post #7 of 10 (permalink) Old 02-16-2017, 06:21 PM
^^^^^ Yup, should have thrown a 420 and 430 pretty quick with empty cats. Any chance the cats disintegrated by themselves and the crap is all sitting at the front of the third cat and plugging the exhaust there?
Jeff K is online now
post #8 of 10 (permalink) Old 02-16-2017, 06:57 PM
Or back in the muffler?
post #9 of 10 (permalink) Old 02-16-2017, 07:19 PM
^^^ Yup, there too.
post #10 of 10 (permalink) Old 02-16-2017, 10:09 PM Thread Starter
Empty cats
Possibly. I will run a pressure test this weekend to see what happens. When my daughter had it towed back here it did have codes for bank 2 cat . After I replaced all the melted stuff and other parts I cleared the codes a drove it down the driveway to see what would happen( I have a long driveway) Even after that and going down the road the codes never came back. There was absolutely nothing inside the cat. They have fairly cheap converters on ebay . Maybe they won't last as long but I may just replace all of it.
tinytim is offline
Car left running after exiting with key fob dajsho 5th and 6th Gen Electronics, Security, Audio and Visual 10 06-11-2016 03:35 PM
99 taurus 24 valve dohc running ruff when hot wjdc00 Maintenance and Repair 5 07-14-2014 01:07 AM
Connection between bad braking and too-tight lug nuts? azure Maintenance and Repair 24 07-07-2014 07:51 PM
Car running warmer than normal Kghow2000 Maintenance and Repair 11 05-04-2014 07:14 PM
Engine keeps running after ignition key is off SkywayTraveler Maintenance and Repair 10 09-25-2013 10:52 AM
