Cooling problem, fans on all the time - Taurus Car Club of America : Ford Taurus Forum
 3Likes
  • 1 Post By Tom S
  • 2 Post By Erick Acosta
post #1 of 8 (permalink) Old 01-10-2017, 05:24 PM Thread Starter
Year: 1999
Model: Ford Taurus Wagon
Hi guys, first timer here. Well, my problem is this, two days ago I changed the heater hoses. But when I removed the driver's side hose, the little tube that has both temp sensors broke, apparently it was corroded. So I went to the local junkyard and found one with only one sensor on it, (it was from a 2001, mine is a 99, but both were vulcans) I thought it was ok for the meantime. So I went on and put it in the car, connected only the connector for the temp sensor, not the sender. After installing everything back I tried to star the engine and it took a really long time, I even had to press the gas pedal like in a carburated car and it started very roughly, like if it had low gas pressure and then it settled in a nice idle, right in that moment the fans turned on and didn't stop until I turned off the car. It's been doing that on cold starts since then.
My question is, does the car need both sensor connected to operate properly? As far as I know, the sender is only for the temp gauge. To make it more clear, my tube has two bosses with one sensor in each, the tube I got from the junkyard has only one boss with a sensor in it
Erick Acosta is offline
post #2 of 8 (permalink) Old 01-10-2017, 06:15 PM
I thought that the sensor and sender as you call them screwed into the engine and not a hose. Can you post a picture of the senders or hose?
post #3 of 8 (permalink) Old 01-10-2017, 09:06 PM
Tom S's Avatar
Year: mult
Seems pretty obvious to me that the PCM no longer has a temperature input and no way is the car gonna run right like that.
jag1959 likes this.
2006 Vulcan 52k GF daily driver
2003 Vulcan 73k My daily driver
2000 Vulcan 112k saved from the scrap yard
2009 Impala 3.0 15k my nice car
Tom S is offline
post #4 of 8 (permalink) Old 01-10-2017, 09:29 PM
^^^^ Yup! No ECT input to the PCM will run the fans on high speed constantly.
post #5 of 8 (permalink) Old 01-10-2017, 11:34 PM
^+1. Erick, you need the "twofer". If you can't find a good 1 at the jy, may try Rockauto online.
post #6 of 8 (permalink) Old 01-11-2017, 01:33 AM Thread Starter
Year: 1999
Thank you very much for your replies guys, that definitely points me in the right direction.
I will post some pictures tomorrow, but you can get the idea by searching "99 taurus water outlet tube" (finally found the name of that thing!) They have it on ebay, but I'm in Mexico, so 45 bucks is a lot for my economy ?
post #7 of 8 (permalink) Old 01-11-2017, 09:53 AM
Can you use two of the fittings in series and that would be cheaper than a double fitting. Not sure of the room you have.
post #8 of 8 (permalink) Old 01-12-2017, 01:00 AM Thread Starter
Year: 1999
It's basically the same if I use two fittings, luckily I found one with the two holes in a jy in good shape, I bought both sensors and the car fired right up, the gauge is working and the fans turn on when they're supposed to. Thank you very much guys, you were very helpful.
sheila and Tom S like this.
No Power Going to Fuses For Cooling Fans afoster80 Maintenance and Repair 2 07-24-2016 09:47 AM
Cooling Fans killing engine? mlrsmasterguns Maintenance and Repair 1 04-12-2016 10:07 PM
AX4S Transmission Problem Scottyman Engine and Drivetrain 5 08-28-2014 09:28 PM
Transmission problem (I think), heat problem, and blinking oil light. BenBrabec Maintenance and Repair 6 03-26-2014 09:58 AM
Why won’t my car start? - Comprehensive No-Start Troubleshooting Guide behlinla Maintenance and Repair 1 01-06-2013 12:52 AM
