Today I lost my battle with PATS - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 14 (permalink) Old 01-08-2017, 07:56 PM
All the above is good and will get you back on the road if the dealer is correct on his diagnosis of a bad PCM. Not sure why it is intermittent on one key and doesn't work on the other. If you have done the transceiver they other component is the halo ring around the ignition key. Did both keys work previously? What was the dealer estimate to fix the issue?
post #12 of 14 (permalink) Old 01-09-2017, 06:50 PM Thread Starter
Year: 2000
I thought the transceiver was the piece with the halo ring? I tried replacing that with two different ones. Both keys previously worked. As for the dealer estimate, they called me on Saturday and told me the PCM could not be reflashed and had to be replaced. I asked them how much it cost and the tech told me that he couldn't tell me until monday. I called the other local dealers to see what they charge and they told me ford doesn't make these PCMs anymore so they couldnt do it. I called my dealer today and they told me they needed another hour to finish the diagnosis. I thought the bad PCM was my diagnosis? They have had my car for almost a week now. I think I am just going to tow it home tomorrow. This dealer is really living up to the stereotype
UPDATE: I went to the dealer and they told me they were pretty sure it was the PCM but they wanted more time to diagnose and wanted to charge me $300 to do it. I told them no thanks and towed it out of there. When it got home I pulled out the PCM and got the number off of it. I ordered a preprogrammed replacement and should have it in about a week.
UPDATE 2: The codes listed on the dealership print out are B1318, B1362, P1000, B1602, and B1681
LuckyNumberSlevin is offline
post #13 of 14 (permalink) Old 01-11-2017, 10:12 AM
Can't you disable PATS with a registered version of Forscan?
rdanville is offline
post #14 of 14 (permalink) Old 01-11-2017, 03:16 PM Thread Starter
Year: 2000
Everything I read said that can't be done. But if it can, it sure would have saved me a lot of time, money, and aggravation
We lost yet another legend today..... bpd1151 Community 2 04-21-2016 08:27 PM
Lost My Breaks Today Need Some Help huntermc6 Suspension, Handling and Brakes 12 08-30-2015 09:33 PM
Getting PATS codes but car seems to start/run fine Shadow351 Electronics, Security, Audio and Visual 2 04-16-2015 12:05 AM
PATS Module Died - What to Do? TaurusNY Electronics, Security, Audio and Visual 23 04-15-2014 09:09 PM
07 pcm replacement question about pats bleedOrange Maintenance and Repair 17 08-12-2013 10:26 PM
