Picked up this for 2nd car- 3.0 v6, NO blown 10amp fuse, new battery, only 4.85 v at pin 55. Did find a splt on pos cable that I taped w/elec tape. Cannot clear the code, evrything seems normal- is there still a problem in wires from power box to PCM harness connector? What is outcome if I do nothing? ANY chance the PCM itself is bad? Any suggestions? All help is appreciated. Thank you.
