Hello there , Looking for info on my '95GL w/3.0. I have been having intermittent trouble with rough idle and stalling out on cold start. If you apply the throttle to rev engine in range of 1000-1500 rpm for approx 10 seconds and release throttle engine will continue to run fine. Temps are anywhere from 10 deg C to -2c or 50 to 28 F. As mentioned it is intermittent , one start will be fine and engine goes to normal idle speed for initial start and next day rough idle. Any ideas would be greatly appreciated.
Thanks for the response Jeff. Not sure when or if plugs , wires... have been changed.
Have done a KOEO test because have had an check engine light flash on and off intermittently while driving. Had P0128 and P1404 codes.
Have not yet checked for vacuum leaks.
I hear a lot of issues referring to the IAC failing.
Wondering ,if my issue is an intermittent one, would plugs, wires ... or a vacuum leak be a consitant problem on each start? When the IAC is failing would it throw a code or would it be intermittent problem ?
Thanks
First thing that comes to mind is your PCV, check/clean the PCV and it's hose. Next thing I would think of is a vacuums leak. Check all hoses, clamps and of course your air cleaner.
Pull one of the plugs out and check, but that's not usually a big temp dependent thing.
A car that is already running rough will have more problems in the cold, pour a can of sea foam in the tank and see if it helps.
Is your car one of the very few 95 Vulcans that left the factory with OBDII? Reason I ask is the large majority of 95 Vulcans had OBDI, and output 3 digit code, not 4 digit.
Was the engine at operating temp when you ran codes and got the 128? If it was not at operating temp, ignore that code. If it was at operating temp, check ECT and its circuit back to the PCM.
Jeff, this car is definitely OBD1 with the small connector under hood on RH side.
The car was not at operating temp when got p0128 code. Attached pic of codes. Code reader did not define p1404 code but googled and found it pointing to egr valve.
