The rust inhibitors breakdown in the coolant over time, I use the same interval as trans fluid, every 2 years/30k. I do it myself and it always involves a flush.
I have used the same interval for Vulcans, Tecs and Yammys although obviously the service is far more critical to a Vulcan.
For my model year and engine (2004 Duratec), initial fill lasts 5 years. Change interval after that is 3 years. This is Ford Gold / Valvoline Zerex G-05.
Valvoline say that G-05 has shelf life of 5 years, the inhibitors break down just the same inside the jug or inside the engine. So the interesting point is why is the change interval 3 years?
One point of view I've heard is water quality when changing won't be as good as initial fill. But Mercedes, who use similar coolant actually say most tap water in the US is ok for coolant changes.
So I believe it's because the 3 year change is a drain and fill. You don't get all the old coolant out so need to swap it more often.
But seeing I get less than half the coolant out in a drain and fill, 3 year drain and fills wouldn't appear to keep the overall coolant age young enough.
So 2 years for a drain and fill would be more cautious. If you are flushing very thoroughly, and using distilled water, I would say you could go 5 years.
The other point is don't stock up on or buy old coolant.
