Got a new battery...now my air conditioner doesn't work!? Suggestions? - Taurus Car Club of America : Ford Taurus Forum
 2Likes
  • 2 Post By Jeff K
post #1 of 6 (permalink) Old 05-28-2016, 09:23 AM Thread Starter
Science's Avatar
Year: 1996
This car is so unpredictable..I recently got a new starter, all of a sudden my air conditioner stops working. I had no idea the battery had anything to do with the air condition.
Can anybody give me any suggestions on what possible reasons me getting a new battery made my air conditioner stop working?
Science is offline
post #2 of 6 (permalink) Old 05-28-2016, 11:21 AM
You say you got a new starter, then say you got a new battery....... which is it? starter? battery? both?
If it was the starter that was replaced, did the AC stop working immediately after the replacement or a few days later? If immediate, check the harness to the clutch. If a day or week after, the AC failure is likely unrelated.
FYI the battery and electrical system are involved in operating EVERYTHING on the car, including the AC system.
jag1959 and ice445 like this.
post #3 of 6 (permalink) Old 05-28-2016, 12:25 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
^+1
A little more detail would help
jag1959 is offline
post #4 of 6 (permalink) Old 05-28-2016, 08:20 PM
If it was the battery and you had it disconnected for a long time and you have the Electronic HVAC controls then you may need to do a reset. I forget the button sequence off hand but its here in the wiki or in the forums. Otherwise as others have stated, we need some more information and clarity on your situation.
2k3SEL is offline
post #5 of 6 (permalink) Old 05-29-2016, 01:06 AM Thread Starter
Science's Avatar
Year: 1996
A/C stopped working immediately after the new battery...I mistyped and didn't even notice it. I got the starter a few weeks later, but the battery stopped blowing cold air after I had the new battery installed.
It blows air, just not cold air.
Science is offline
post #6 of 6 (permalink) Old 06-01-2016, 08:42 PM
Do a search for EATC Self Test. There are numerous posts in the forums depending on your model and year.
Climate Control Only Blowing Hot Air
Air Conditioner Blows Hot Air
Basically this does the following (copied from another post I found)
This test exercises all the vacuum switches and electric actuators, then it displays an error code for the malfunction if there is one in the ac display.
Unfortunately it is only for the Ford products with the digital climate control.
DIAGNOSIS AND TESTING (Continued)
• To enter the self-test, press the OFF and floor buttons simultaneously and then press the AUTO button within two seconds. The display will show
a dashed line in the center of the climate control display window of the integrated control panel (ICP).
• The test may run as long as 30 seconds. Record all DTCs displayed. The self-test is completed when 888 appears in the center of the climate
control display window of the ICP.
• To exit the self-test and retain all intermittent Air Temperature Powertrain DTCs, press the ‘‘—’’ (cooler) side of the TEMP Sensor Circuit Control/Emissions
button. The RCC module will exit the self-test High Diagnosis(PC/ED)and retain all intermittent DTCs.
• To exit the self-test and clear all DTCs, press the front defrost button. All RCC module DTCs will be cleared.
• Always exit the self-test before powering the system down (system turned off).
2k3SEL is offline
Battery Rant/Resolve? Rickaren Taurus and Sable General Discussion 16 02-03-2016 10:22 PM
Got a new car battery, now my air conditioner doesn't work?? What could it be? Science Maintenance and Repair 2 09-19-2015 11:47 AM
Battery dying -- cables? snarkdiva Maintenance and Repair 28 01-04-2015 10:46 PM
Check Engine light: Check the battery! Brcobrem Maintenance and Repair 10 07-16-2014 03:00 PM
Why wonít my car start? - Comprehensive No-Start Troubleshooting Guide behlinla Maintenance and Repair 1 01-06-2013 12:52 AM
