2005 Taurus slow washer fluid stream on driver's side (again) - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 03-23-2016, 04:47 PM Thread Starter
Annorax's Avatar
Year: 2004
Question 2005 Taurus slow washer fluid stream on driver's side (again)
Hello all,
My wife's washer fluid nozzles are acting up again in that the passenger side nozzle shoots fine but the driver's side nozzle shoots much lower and doesn't quite reach the windshield.
Last time the tube under the hood was physically torn so most of the fluid was not making it to the driver's side (farther) nozzle. With the tube replaced and everything looking fine, it's happening again (after a few months or so) in which the driver's side nozzle shoots very low.
Any ideas what might be the problem this time? Nothing looks visible obstructed. There is plenty of fluid. Is the washer fluid motor getting weak with age or something?
2004 Ford Taurus SES
Mods I am planning on doing: (some day)
- Digital Compass & Auto-dimming mirror
- Daytime running lights
- Numeric keypad on driver's door
- Rear disc brakes & rear spoiler
- Power passenger seat
- Something to fix those trunk hinges
- Moonroof (later down the line)
- Traction & Stability Control (is this even possible?)
Annorax is offline
post #2 of 6 (permalink) Old 03-23-2016, 05:27 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
If there's no damage to the line then more than likely there's an obstruction in the line or nozzle. If the lines all check out. you can try disconnecting it and blowing it back through the nozzle with compressed air or just replace it. They are inexpensive
jag1959 is offline
post #3 of 6 (permalink) Old 03-23-2016, 05:44 PM Thread Starter
Annorax's Avatar
Year: 2004
Thanks - I was hoping it would most likely be some sort of blockage and not something wrong with the motor. How do I take off the line from the passenger's side end and from the nozzle on the driver's side? I tried pulling and twisting (but not too hard, didn't want to break anything) but they wouldn't budge.
Annorax is offline
post #4 of 6 (permalink) Old 03-24-2016, 09:01 AM
twist it first, once it's loose then pull (not pull and twist)
you need to remove it from the bracket that secures it near the strut mount (passenger side) for easy access. sorry no pics, did it several times when I was swapping hood.
and
and
lincolnshibuya is offline
post #5 of 6 (permalink) Old 06-13-2016, 04:04 PM
Year: 2002
Model: Ford Taurus Wagon
Folks,
I have this problem on a 2002 wagon. The passenger side feed line was rotted so I replaced it with a slightly large clear tube. I'd like to check the driver side connections but I'm not sure how to get the insulation pad off. I see there are about 6 large plastic caps holding it in place. Do these just pry off?
Bob
lswpubrw is offline
post #6 of 6 (permalink) Old 06-13-2016, 06:32 PM
don2775's Avatar
Yes, it's best to remove the with a molding removal tool, but they will just pry off as well.
don2775 is offline
2005 Ford Taurus Studders or hestates from a stop or slow speed. Chris92 Engine and Drivetrain 5 07-02-2013 01:09 PM
Removal of rear drivers side quarter panel? trcoburn Maintenance and Repair 1 05-23-2013 02:59 PM
Pictures of my 2005 Taurus. the_intimidator_02 Taurus and Sable General Discussion 8 05-01-2013 10:23 AM
OBD II Scan tool canít connect to 2005 Taurus computer. qcy2k6 Maintenance and Repair 5 04-26-2013 01:59 PM
2001 Taurus Drivers side CV Joint failing? shorrock Maintenance and Repair 3 04-08-2013 12:06 PM
