Flat Battery !!!!!!!!!!!!!! - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By Automender12345
post #1 of 6 (permalink) Old 01-20-2016, 08:06 PM Thread Starter
Hi All,
just a quick question, i bought one of those heated seat pads, and left it connected, instead of disconnecting it, hence morning after flat battery Anyhow bought battery charger, fully recharged it, put back on morning after, started okay, but, it did not fire up as quick as it did before, i noticed a clicking noise from i think the engine compartment when it started for about 3 seconds, since i recharged the battery, it feels at times like it will not start, but it does.
I know the obvious answer is that the battery is dud now, but, it is reading 14 volts when idling, 13 volts when turned off ?????
the only reason i am asking this is, before i go and spend $100 plus bucks to buy a new battery, is there a possibility it could be something to do with , starter motor, or alternator, or could it be that the engine management system is re setting itself, if you know what i mean ???
Thank you for your time.
Bob
bfishwick is offline
post #2 of 6 (permalink) Old 01-21-2016, 01:36 AM
Check your battery terminal connections for corrosion and tightness. Or you killed the battery because of the deep discharge situation. An old battery will easily be killed by a deep discharge,
coachjfk likes this.
post #3 of 6 (permalink) Old 01-21-2016, 05:19 AM Thread Starter
Thanks, its just after six this morning, just checked voltage before I started the car, and is only putting out just over 10 volts, so new battery it is.
Thanks
Bob
post #4 of 6 (permalink) Old 01-21-2016, 08:16 AM
Originally Posted by bfishwick View Post
Hi All,
Bob
1. When the battery is discharged fully, (deep discharge) it will be damaged. Car use batterys are not intended for that.
2. When the battery is down, or disconnected, the car looses it's memory. It will need to relearn it's parameters again. Few cold starts and warmups and it will relearn that.
Tranny shifts are learned to your driving habits, that will need to be re-learned too.
post #5 of 6 (permalink) Old 01-22-2016, 03:30 PM
I'll put up with a lot of issues while driving that are annoying. Having a marginal battery is NOT one of them. I like a car that starts when I want it to. Not only when it wants to.
coachjfk is offline
post #6 of 6 (permalink) Old 01-23-2016, 12:56 PM
DoctorHugocat's Avatar
Year: 1995
+1. I'm happy to have a car with a mind of its own as long as we mostly agree.
DoctorHugocat is offline
200 Ford Taurus SES U Engine, Battery Light Saga connordo Maintenance and Repair 0 07-08-2015 07:30 PM
Battery dying -- cables? snarkdiva Maintenance and Repair 28 01-04-2015 09:46 PM
Check Engine light: Check the battery! Brcobrem Maintenance and Repair 10 07-16-2014 02:00 PM
Battery Charging Issue that has me puzzled ! k8crd Maintenance and Repair 14 02-08-2014 08:17 AM
