1998 Taurus - 12 valve OHV AC low side is low, high side is low - Taurus Car Club of America : Ford Taurus Forum
post #1 of 3 (permalink) Old 06-06-2015, 04:18 PM Thread Starter
Last September, I knew the high side service port was leaking. I could actually see the R134 bubbling in it. However, I was able to screw the plastic cap on and make it through September and October.
Fast forward to now. Both the low side and high side were coming back at zero psi. So, I replaced the low side and high side service ports, pulled a vacuum for an hour, and then it held vacuum for an hour. Figured everything was good in the world so I went ahead and put freon in it. Thing is, after 34 oz. of freon, the low side gauge continued to show 20 psi and the high side gauge continued to show 150 psi even though more freon was going into the system.
Added the freon with the vehicle running and the AC on cold and full blower. The AC clutch was not coming on initially, as expected. As I put more and more freon in, the clutch cycled longer and longer until it stopped cutting off. It stopped cutting off after putting 24 oz. of freon in the vehicle. Thing is, I added another 12 oz. and the low side remained at 20 psi and the high side at 150 psi the entire time. I could not get the low side into the 35-45 psi range as recommended for an ambient temp of 80 degrees.
The AC is blowing extremely cold right now, but I know something is not right.
Anybody know what is going on?
fabsroman is offline
post #2 of 3 (permalink) Old 06-07-2015, 07:01 AM
wjc
wjc's Avatar
Borrow another set of gauges. At 20 PSI the low side switch would be cycling rapidly, if it even allowed the clutch to engage at all.
wjc is offline
post #3 of 3 (permalink) Old 06-07-2015, 10:31 AM
As a matter of principle, i always add a can of UV dye to a refill so i can
see where its leaking (if it still is). I assume you changed all the O rings
you could get too when you did the refill?
One other thing to do that rarely gets done, is to clean out the condenser.
What i have done is to remove the lower cover between the radiator
and the condenser and shoot water up the gap and flush out the crud.
My harbor freight gages have served me well, but there NOT pro quality.
Probably around $50 with a coupon or so on sale.
http://www.harborfreight.com/quickvi...index/id/2463/
My last gen three repair was the change out the ac clutch pulley on
the car without degassing the system. That was a lot of fun.
soundu is offline
1998 Taurus SE Comfort Carlsonnr Introduction Forum 14 06-23-2015 06:22 PM
My98STL's 1998 Ford Taurus SE (Bessie) My98STL Taurus and Sable Project Log 35 11-01-2014 10:29 AM
99 taurus 24 valve dohc running ruff when hot wjdc00 Maintenance and Repair 5 07-14-2014 01:07 AM
Impossible to connect (ac manifold gauge) to low side port (2004 Taurus) TheEgg Maintenance and Repair 3 07-10-2014 09:33 PM
Power Steering Pump Replacement + High Pressure Line Monsoon Suspension, Handling and Brakes 0 05-04-2013 09:44 PM
