My 98 Taurus fault codes. What do first? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 2 (permalink) Old 04-06-2014, 02:28 PM Thread Starter
How to best approach repair of my wife's Taurus? What do first?
Much thanks for ANY advice!
98 Taurus SE (3.0 L DOHC Duratec 30 V6)
Symptoms:
Wife says car stalls in morning backing out.
I think engine runs rough here and there; perhaps accelerating, hard to say.
Check engine light been on long time.
Fault codes:
P1742 - Torque Converter Clutch Solenoid Circuit Failed On *
P1744 - Torque Converter Clutch Solenoid Circuit Performance *
P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0401 - Exhaust Gas Recirculation Flow Insufficient Detected
P0155 - (Pending fault) O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
Also, perhaps relevant:
No lights on football work, HVAC controls work, No radio at all.
-Dimmer has no effect.
-All fuses checked for continuity and contacts cleaned.
-Pulled football, cleaned all connectors.
All lights (running, brake, blinks, dome, etc.) work. No burnt bulbs.
I did just replace the blink unit.
I did replace oil pan gasket couple months ago and degreased engine.
joenashville is offline
post #2 of 2 (permalink) Old 04-06-2014, 06:33 PM Thread Starter
Okay, I answered my own questions think:
For the P1742, P1744 codes (TCC related) I will:
  • flush trans fluid
  • Check harness connector for trans fluid. From the forum: I removed the airbox and on the top of the tranny there are two wire harnesses, unplug the white one( this harness is the smaller one with 9 wires) if their is tranny fluid in the harness it will cause a false signal to the Torque converter solenoid. All that needs to be replaced is a small o ring on the inside of the tranny. The hard part is putting it in. You have to remove the side cover on the tranny.
  • Replace TCC solenoid
  • And hope trans is not failing.
For the P0135, P0155 codes (O2 sensor heater circuits related)
For the P0401 code:
  • DPFE needs to be replaced.
I haven't figured the radio deal yet.
2004 Ford Taurus rough idle, loss of power, codes jumping Taurusaurus237 Maintenance and Repair 16 12-22-2016 10:25 PM
2005 Taurus P0401, P0300, P0316 Error Codes PWill Maintenance and Repair 1 03-09-2014 02:08 PM
97 Ford Taurus (Vulcan) codes and loud engine Walbeb Maintenance and Repair 2 07-09-2013 05:14 AM
Two diagnostic codes on my new Taurus SEL. Ocelot Maintenance and Repair 10 04-03-2013 06:45 PM
