HI! I noticed at the store that something was dangling down underneath the car. I don't know the names of things, so I'll describe it. If my descriptions don't mean anything, I'll post a pic.
Dangling down, there was a "canister" about 2 X 2.5 inches with a T hose connection at the top. At the T there were two hoses, one smaller than the other. Neither hose was connected to anything.
The smaller hose seemed to go to a small diameter, bent, metal tube that wasn't connected to anything either that was near the EGR valve. So, I assumed that is where it went. The nipple on the metal tube fit snugly into the hose, so I trimmed the split end of the hose and reconnected that one. I "think" that is where it should go. I hope. ???
The big question, though, is where does the other one go, on the other side of the T connector? The end was frayed so it seems I should be able to find another frayed end somewhere. But within the length of the hose, I couldn't find another hose, even after removing the air filter box. Seems it should be on the driver's side, since the frayed piece doesn't reach anywhere else.
I'm getting a 326 error code, which would make sense since the other side of the T was disconnected from emissions.
Assume I have a little knowledge, but beginner for sure. I'm working on my car because I'm tired of going to mechanics who charge me for parts, but don't fix the problem, and don't know the answer to any questions I ask, like where does this hose go?
Thanks!
Thanks!
