Question 2 - Taurus Car Club of America : Ford Taurus Forum
post #1 of 13 (permalink) Old 07-08-2013, 11:10 PM Thread Starter
Question 2
1) gave a jump the other day and the other vehicle must have a serious short because as soon as the guy hooked up cables it killed my battery. Now with a dead battery of my own and it won't take a jump. But every time I've tried to start the wipers comeon, switch off. Is this an indicator of something like some imports?
2) now that there has been over $2K spent on repairs and an almost new cooling system, I want to tackle the vent issue (dipstick gets pushed up) on the trans. Mine has a pinched metal cap instead of rubber like the ones I've seen in topic searches. I take it that once I pry it off it's trash? Installing a rubber line after cleaning it out good enough or should I replace vent with new style?
ramman01 is offline
post #2 of 13 (permalink) Old 07-08-2013, 11:11 PM
The White Falcon's Avatar
Were the jumper cables hooked up properly on both ends? Some cars (not the Taurus) require you to put the negative cable somewhere else under the hood...
Bradley.
Holly: 2003 Taurus SES Deluxe, Duratec, spoiler, moonroof, OEM Centennials, JBL Audio system, other enhancements. April '14 COTM winner.
See more details
What's next, 'the eyes that rolled at my massive ego'?
The White Falcon is offline
post #3 of 13 (permalink) Old 07-08-2013, 11:24 PM
cjjames23's Avatar
The vehicle being jumped "should" have the ground placed on the block somewhere
cjjames23 is offline
post #4 of 13 (permalink) Old 07-09-2013, 12:14 AM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
Every time I have had a battery/voltage issue I have had the 'wiper warning'
jag1959 is offline
post #5 of 13 (permalink) Old 07-09-2013, 02:51 AM
Guy on the other end might have switched the cables around creating a direct short. Make sure the guy on the other end know's what they're doing, otherwise do it yourself.
The reason you clip onto the block is to prevent any possible sparks created during the final connection from igniting the battery fumes (hydrogen) and causing an explosion. If someone attaches to the battery - instead of the block it won't cause any damage.
1) replace battery and see if it goes away
2) try to find an OEM vent cap from a junkyard to see if that fixes it
behlinla is offline
post #6 of 13 (permalink) Old 07-09-2013, 02:56 AM Thread Starter
When I got out to check, he had it grounded to the metal radiator mount on his vehicle. He said it sparked a lot. (Grrr!) He wanted to try again with my truck since it had a bigger battery! No way. We put in a new battery without issue. I told him how to troubleshoot for a short and I did some checking and told him what to check and he got it fixed. I can't work due to disabilities and have no income so I called hoping he would help pay whatever the pro rated amount is on my battery but he's not returning my calls. No good deed goes unpunished! LOL! I wondered about the wipers. On a montero I had, all warning lights would come on if there was a problem with the charge circuit. I thought maybe it was something similar, but like my montero, it's not mentioned in any of the manuals. Thanks all.
ramman01 is offline
post #7 of 13 (permalink) Old 07-09-2013, 11:30 AM
jag1959's Avatar
I may seem abrupt to the person I am helping but I always make the connections myself. BTW the exploding hydrogen thing is no joke, I had a college classmate with a tough luck scar from it.
jag1959 is offline
post #8 of 13 (permalink) Old 07-09-2013, 12:12 PM
^+1 with jag. I'll always insist on doing the hookup myself if my car is involved. Whether it be on the giving or receiving end.
sheila is online now
post #9 of 13 (permalink) Old 07-09-2013, 07:00 PM Thread Starter
I figured he would have it hooked up right since I had shown him twice previously and reminded him again before I got in the car. It was right, just a combination of a serious short and bad battery in his vehicle. And I remember what it's like to have a battery blow up in your face! Wife is upset since we just got all that work done and she was able to drive it again just 3 weeks ago and now it's parked (again). Put the truck battery in but it's too big. On a side note, this site & you members are really helpful. Thanks for the replies. JimBob
ramman01 is offline
post #10 of 13 (permalink) Old 07-09-2013, 07:05 PM Thread Starter
Also, I'm glad it wasn't my truck. The alternator is regulated thru the pcm and the battery is a lot more expensive.
ramman01 is offline
03 Taurus subwoofer and amp question. Shrek Electronics, Security, Audio and Visual 27 08-13-2013 02:25 AM
1995 Ford taurus Flexplate question... square97 Engine and Drivetrain 11 07-16-2013 06:18 PM
Yet another AX4S question SittinInTheDriversSeat Maintenance and Repair 1 05-21-2013 07:15 PM
Belt Tensioner Removal Question - 02' Vulcan emtpjimd Maintenance and Repair 1 04-24-2013 01:11 PM
Mach RCU Question gqneon Electronics, Security, Audio and Visual 6 04-05-2013 09:56 PM
