Changing O2 sensors - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 05-23-2013, 09:57 AM Thread Starter
Changing O2 sensors
Have to get some work done on my car, & one of the things they mentioned was they needed to replace the O2 sensors. I've got to take it in anyways, since the timing cover needs to be replaced (it's leaking) and I definitely do not feel comfortable doing that repair myself.
On review, it seems somewhat easy, but I'm not sure. How easy is replacing the sensors? I'm a relative novice when it comes to repairs. I can do basic stuff myself - oil change, spark plugs, brakes, etc - but some more complex stuff makes me nervous. Also, how many sensors are there? I've seen 2 & 4 in different places.
My Taurus is a 2006 Taurus SEL Vulcan 3.0L V6.
cpusavant is offline
post #2 of 11 (permalink) Old 05-23-2013, 12:30 PM
2 upstream (pre-cat) o2s with green elec. conn. 2 downstream (post-cat) o2s with blue elec. conn. Usually no need to replace the 2 downstream. Standing at the front of the car, hood open, look behind and to the right of the radiator for the green plug. This is your bank#2 sensor#1 (upstream). Now, look between the eng. and firewall for the other green plug. That is your bank#1 sensor#1 (upstream). You may be able to r&r the 1 behind the radiator with a 7/8" (22mm) combo wrench from above or below (air dam removed). Access to the firewall o2 is a bit more challenging. I suggest you go to Harbor Freight Tools and check out their selection of various o2 sockets, crowsfeet and offset tools. A parts store may offer an o2 tool set in their loaner program.
post #3 of 11 (permalink) Old 05-28-2013, 09:28 AM Thread Starter
Thanks Sheila. I think I found the two upstream ones, both near the spark plugs, correct? Also, the shop service manual I have says only 2 HO2S required. Presumably they're just referring to the upstream ones?
Appreciate your help in all this.
post #4 of 11 (permalink) Old 05-28-2013, 11:40 AM
Harbor Freight has some generic O2 tools. What i really found helpful
(especially on the bank 2 sensors) is a offset tool/wrench combo.
I believe i got mine at advance auto for $25/30 dollars or so.
soundu is offline
post #5 of 11 (permalink) Old 05-28-2013, 07:15 PM Thread Starter
I'm assuming the two pictured here are the upstream ones that I should be concerned about, correct?
post #6 of 11 (permalink) Old 05-28-2013, 10:36 PM
They're in the 2 locations I described above. Remember, the 2 upstream will have green elec. conns., the 2 downstream will be blue.
post #7 of 11 (permalink) Old 06-28-2013, 01:55 PM Thread Starter
RockAuto has 2 upstreams listed - 11" wires & 15" wires. Does it matter which I get? Is the longer wire preferred, or is there a concern that the longer wire could rub against other engine parts & become frayed/damaged?
post #8 of 11 (permalink) Old 06-28-2013, 04:02 PM
SoNic67's Avatar
They are different lengths for each location. What I do is to use the Motorcraft site to find the exact part number (per VIN number) and after that cross-reference it on RockAuto or similar sites.
SoNic67 is offline
post #9 of 11 (permalink) Old 06-29-2013, 09:45 AM
Why was it so hard just to measure the length of the one that was on there?
soundu is offline
post #10 of 11 (permalink) Old 06-29-2013, 11:23 AM
SoNic67's Avatar
Because usually you buy the new part before you take out the old one.
Otherwise you need to take the bus or taxi or walk to the parts store.
SoNic67 is offline
TPMS Learning mattcow 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 15 11-30-2014 09:59 PM
Changing spark plugs on 06 Vulcan cpusavant Maintenance and Repair 15 04-09-2014 03:27 PM
O2 sensors tbm3fan Maintenance and Repair 3 05-23-2013 09:09 PM
Unplugged connector,where does it go? Nick3.0L Maintenance and Repair 20 05-13-2013 03:22 AM
does anyone know where both the coolant temp sensors are at peterf1992 Maintenance and Repair 2 05-08-2013 09:03 PM
