Where I can find splice tube to connect rubber hose? - Taurus Car Club of America : Ford Taurus Forum
Old 02-14-2013, 09:57 PM   #1 (permalink)
Member Number: 48633
Default Where I can find splice tube to connect rubber hose?
Hello all,
Is there a splice tube that can be used to connect two rubber hose together?
For example, if you cut the power steering return rubber hose in half, then connect them together. I figure out that a small plastic tube inserted in both end of the hose and tighten with clamps.
Does any store sell the stuff like that? what name for it?
Thank you
Old 02-14-2013, 10:27 PM   #2 (permalink)
Member Number: 45250
Drives: 2002 Ford Taurus SES. 24V Duratec. Metallic Gray. :)
Simon182 has a spectacular aura about
Of course there is! Not sure what it's called but you'll find it at a hardware store or an auto parts store. Tell the employee what you want and hopefully they have it
Simon182 is offline   Reply With Quote
Old 02-14-2013, 10:51 PM   #3 (permalink)
Member Number: 52362
Drives: 1998 Windstar 3.0 U Vin
las59 is an unknown quantity at this point
Originally Posted by q0987 View Post
Hello all,
Thank you
Go to your local hardware store and ask for a brass barbed connecter.
las59 is offline   Reply With Quote
Old 02-14-2013, 10:53 PM   #4 (permalink)
Seriously Senior Member
The White Falcon's Avatar
Member Number: 51308
The real question is why did you cut your power steering return hose in half?
Bradley.
Holly: 2003 Ford Taurus SES Deluxe, built in Chicago on 11/08/2002. Duratec 24V DOHC, with Luxury and Convenience Package, moonroof, CD changer, and XM Radio. Mods: "Amazing" Stock Audio paired with Pioneer speakers, woodgrain interior, tinted taillights.
The White Falcon is offline   Reply With Quote
Old 02-14-2013, 11:00 PM   #5 (permalink)
No. I will not do so.
I have an old issue of very slow leak of PS from the end of return hose.
After I got some advise from the experts here, I replace the original clamp with a different one. After long period of time, the slow leak stops. The original slow leak is very minimal, maybe one or two drops per week where I can see some oils on the outside of the rubber hose.
Today, I got a new issue, please see my other post
See Power Steering Oil on top the cap
I am not sure which really causes the problem. So just want to know the worse case what I should do. The nipple of the return hose is famous for its fragile, so I have do this disconnection as my last choice.
Old 02-14-2013, 11:01 PM   #6 (permalink)
Very helpful.
Thank you
