How do i disassemble and clean the EGR valve? - Taurus Car Club of America : Ford Taurus Forum
Old 02-14-2013, 06:30 AM   #1 (permalink)
Member Number: 50666
Drives: 2001 Ford Taurus SE 2010 Ford Mondeo 2.2tdci
pimpninja will become famous soon enough
Default How do i disassemble and clean the EGR valve?
Hello all,
The title says it all. The bull is giving me a P0402 error, which is too much flow in the egr valve. I would like to take it out and clean it. Has anyone done this and if so, what are the steps and how can i clean it? Can i use carb cleaner?
As always guys, thank you!
pimpninja is offline   Reply With Quote
Old 02-14-2013, 08:40 AM   #2 (permalink)
Breeves002's Avatar
Member Number: 49890
Usually P0401/402 are to do with a bad DPFE sensor. What you can do to test if it really is giving too much flow is pulling the vacuum tube off the top of the egr and feel for suction at idle. There should be none. If there is then you need to replace the EVR valve (EGR vacuum solenoid). 99% of the time the DPFE sensor must be replaced though.
If the EGR valve is stuck open you will have a rough idle. Is this happening to you?
If you still want to clean the valve, it's two lower nuts and two upper bolts. Remove the valve. Make sure to replace the gaskets after you clean it.
Sent from AutoGuide.com App
2012 Kia Soul Base AT 1.6GDI
CLICK HERE
Old 02-14-2013, 10:05 AM   #3 (permalink)
sheila is just really nice
Pimp, source the Borg-Warner part#BWD EGR631 dpfe (egr pressure sensor) from Advance Auto or O'Reilly.
Old 02-14-2013, 06:52 PM   #4 (permalink)
Thanks for the reply. No rough idle at all. The rpm is as steady as a rock
and the engine is nice and quiet. The check engine light comes on and off for times loke 4-5 days on and 2-3 days off.So it may sound like a DPFE sensor?
Old 02-14-2013, 08:28 PM   #5 (permalink)
^ Yes.
Old 02-14-2013, 08:54 PM   #6 (permalink)
Breeves002's Avatar
Yes. Replace DPFE.
CLICK HERE
Old 02-20-2013, 07:32 PM   #7 (permalink)
Quick update, didn't touch the EGR valve, just changed the DPFE and so far 120+ miles, no check engine light. Thanks for tip guys.
Cheers.
