![]() Member Number: 49890
This is my aunt's car. 2001 Sable Duratec. Maintained well as far as I know.
I have read the no start guide. I'm a bit confused here. Car is 45mins away from me so I want to get ideas out before I go out there. First the background: had a dead battery. Replaced it. Made clicking when trying to start. It cranks just fine now since the battery was replaced. She has had it die twice while the motor was running. Started after jumping. That was before the battery was replaced. What's been checked and done; -new battery, car cranks strong -fuel pump primes every time (checked 10 times) She has no way to check the pressure unless I go do it for her. -inertia switch checked and the button is depressed -alternator was tested fine -theft light doesn't flash when cranking -tach doesn't move when cranking (not sure if this applies except on a scan tool though). -foot to the floor, won't start -a small amount of throttle applied, won't start. -NO CEL and no driving symptoms before this happened. Cel does cycle KOEO. So I think I didn't forget anything. NSS problem won't let you crank the motor at all, right? Next steps and ideas? Check fuel pressure? Going to go out and try to help her if I must. Thanks for the help. Sent from AutoGuide.com App
#2 (permalink) | |
Cake monster
Member Number: 18214
Drives: none right now
Thanks for the ideas. Pedal to the floor won't normally let it start but if the motor is flooded it sometimes helps.
I will check actual pressure and check spark and pull a plug when I can. I have to get to the car though. Sent from AutoGuide.com App
Member Number: 1771
Drives: 97 SHO Sedan, 00 SEL Sedan
WOT on any Taurus will only let the car crank. Car will not start with throttle wide open.
--Nick M. | Blythewood, SC | AAP/Atlanta Built Bulls -Silver Frost MC 2000 Ford Taurus SEL | DOHC/AX4N | 184K -Toreador Red MC 1997 Ford Taurus SHO | DOHC/AX4N | 149K --Wood paneled 1991 Mercury Grand Marquis LS Colony Park wagon | OHV/AOD | 180K ish? Sold.... --Driftwood MC 1987 Ford Taurus GL Wagon | OHV/AXOD | 254K - now owned by major!! Scrapped... --Sand Beige 1987 Ford Taurus GL |197K | OHV/AXOD |
#5 (permalink) | |
Check and make sure the warning lights work (CEL, THEFT, charging system, etc).
Check for any codes with your scan tool. This will also confirm the PCM is alive. Test for fuel pressure with scan tool or gauge. Since the pump is working, make sure you have gas in the tank (you might add a few gallons to the tank to be sure). Check for spark during cranking. Check for RPM signal on scan tool during cranking Try holding pedal half way (injection is disabled at WOT during cranking) |
All lights work. CEL, theft (although doesn't flash when cranking), charging system, etc.
When I get out there I will try those things. PCM was replaced 5 years ago actually or I believe it was. Did try cranking with the pedal down some of the way. Sent from AutoGuide.com App
What's the best way to check for spark during cranking? Screwdriver (grounded) to coil pack like a normal spark strength test or can you do it from the spark plug wire end?
I need to make sure the coil pack is actually plugged in correctly. No stored codes that I know of though. Will make sure when I go out there Wednesday.
#9 (permalink) |
I like to test at the coil if possible because it rules out the wire. But you can test at either end.
Screwdriver grounded to the engine block will work. Keep your hand off the metal part. Remember to always provide a path for the spark to prevent stressing the coil. |
#10 (permalink) |
Okie dokie. Just a screwdriver and some copper wire to the engine block hopefully will work. Of course I won't touch the metal haha. Don't feel like getting zapped!
What socket size are our spark plugs?
