Help me identify how to disconnect this fuel connection? - Taurus Car Club of America : Ford Taurus Forum
Old 01-28-2013, 01:39 PM   #1 (permalink)
Member Number: 52566
Drives: 2004 3.0L
DoTheEyeThing is an unknown quantity at this point
Default Help me identify how to disconnect this fuel connection?
I'm trying to replace a fuel pump so I've been disconnecting some of the lines leading up to it. This connection leads up to the charcoal canister - it seems to swivel with the other line in it - not sure how to release it. I thought maybe the white tab would lift out but I can't seem to get a flat head screwdriver under it.
In this image you can see one of two rectangular holes in it.
Any help would be greatly appreciated!
DoTheEyeThing is offline   Reply With Quote
Old 01-29-2013, 11:52 AM   #2 (permalink)
Kestas's Avatar
Member Number: 7909
Drives: 01 Sable GS, 3.0 Vulcan vin U, 63K
Kestas is an unknown quantity at this point
I'm not positive, but I think the white piece in the connector is a u-shaped clip, and it's pulled out radially from connector.
Can you push from both slot ends with a small screwdriver?
Kestas is offline   Reply With Quote
Old 01-29-2013, 12:01 PM   #3 (permalink)
Member Number: 48633
Check this out and it shows you exactly how you should do it!
How To Replace a Fuel Pump (1999 Ford Taurus) - EricTheCarGuy - YouTube
Old 01-30-2013, 05:32 AM   #4 (permalink)
Member Number: 51650
Drives: 2004 SEL Vulcan
Rogerm60 is an unknown quantity at this point
You are supposed to press in on the clip to release. I know you can remove it but that is not necessary. I usually spray some WD40 on it and twist back and forth to loosen it up, then pull straight apart while squeezing the clip.
Rogerm60 is offline   Reply With Quote
