Member Number: 2904
I can't add fluid until I get out of work later in the day. But, the car developed a leak in a line that crosses the front of the car. I drove the car and slowly started noticing some slip issues. When I got off the highway it would slip terribly at low speeds. I babied it home, but it was really bad on a couple of hills.
Do I have any chance or is it now shot? It is a 98 taurus with a ax4n that HAD mobil 1 in it. Now there probably isn't much left. My plan was to get some cheap fluid and see if it will run. If not, no sense in fixing the line. The car has rust and 194,000 miles. I just hate to see it die like this. What are my odds that adding fluid will get her going again? |
Member Number: 1771
Drives: 97 SHO Sedan, 00 SEL Sedan
Get cheap fluid and see what happens. Any way you could get a piece of rubber hose and some hose clamps to put in place of the rusted out line?
--Nick M. | Blythewood, SC | AAP/Atlanta Built Bulls -Silver Frost MC 2000 Ford Taurus SEL | DOHC/AX4N | 184K -Toreador Red MC 1997 Ford Taurus SHO | DOHC/AX4N | 149K --Wood paneled 1991 Mercury Grand Marquis LS Colony Park wagon | OHV/AOD | 180K ish? Sold.... --Driftwood MC 1987 Ford Taurus GL Wagon | OHV/AXOD | 254K - now owned by major!! Scrapped... --Sand Beige 1987 Ford Taurus GL |197K | OHV/AXOD |
Member Number: 2904
That is my hope. I really beat the old girl to get home. It was 4 am and coming home from a NYC airport. A tow and repair in the city would have cost me more than the car is worth. My only hope is that the 10 degree weather kept things a little cooler than usual. If this thing works, I will be very impressed. I won't know until later. Have others gotten away with this, or does this usually mean death?
Member Number: 7489
Fords are usually forgiving and get you home, but wow...the transmission in a Taurus? Nick's got as good an idea as any. If it's one of the cooler lines from the tranny to the radiator or back, use double clamps at each end of the rubber hose, and sand the burrs off where you cut the rotted line out. If you have a flaring tool, use it to make a double flare for the hose to fit over (extra leak prevention, especially if it's the high-side line).
As long as you didn't rev the crap out of the car to get it uphill, you have a decent chance of no permanent damage.
"There is no try, or try not. There is only do, or do not." Someday, some hairy big-eared little alien is gonna steal that from me. |
Member Number: 20379
Drives: '97 Taurus GL 3.0 Vulcan
Driving a 1980 Buick Skylark near O'Hare Airport when steam appeared in front of the hood (busy road maybe 1981). Pulled off road when I could -by then car was struggling to move forward. Opened hood looked under. Tranny fluid pouring onto ground and heavy steam was coming from vent on top of tran case--like a tea kettle!!! Had car towed. Dealership wanted to replace tranny--told boss--we decided to have it filled and I drive elsewhere. Just kept driving the car another 30-40,000 miles and then had it traded over year later. Only issue from incident was slightly harder shift and slight burnt smell from oil.
Possibly Crazy
Member Number: 51308
Rep Power: 3 ![]() |
I remember when one of my dad's work trucks (98 Chevy) did something similar. I saw him pull up at the place we were at, come inside, and bam, this shower of fluid starts pouring out of the underbelly. Bye bye transmission fluid... He called the main yard and they came and towed it off.
All the Chevy's he drove were maintenance pigs. His F-250 hasn't given him any trouble.
Bradley. ![]() Holly: 2003 Ford Taurus SES Deluxe, built in Chicago on 11/08/2002. Duratec 24V DOHC, with Luxury and Convenience Package, moonroof, and CD changer. Mods: JBL/Mach hybrid paired with Pioneer speakers and a JBL custom subwoofer, woodgrain window switches with a Sable Platinum shifter surround, Taurus SHO floormats. |
Member Number: 2904
ok, here is the situation. I replaced the piece of line with hose. I have it filled to the proper level. It was down 6-7 quarts. My once beautiful shifting tranny, now has a hard 1-2 shift. It hangs in 1st too long if I am on the accelerator. I have to accelerate slowly or left off the gas to allow it to dump into second, otherwise,I will get the hard shift. All the other gears are smooth and there is not slipping.
So, what is the verdict? |
Member Number: 35029
Rep Power: 5 ![]() |
It might be that the burnt oil inside clogged the filter and now you have lower pressure.
You might need to drain the transmission pan and replace the filter. Driving it like that it only accelerate the wear on the clutches... |
#9 (permalink) |
Member Number: 7489
It works, dunnit? As Sonic said, give the poor thing some service and count your blessings. Panic if that doesn't help things. You are freaking lucky you are where you are with it.
#10 (permalink) |
Rep Power: 22 ![]() |
Along with fluid/filter change, may swap vss.
