What do I need for a cable to Rod shifter conversion? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 01-25-2013, 10:09 PM Thread Starter
Chapter: Northern
I recently bought an 89 SHO. The Cable shifter is missing a bushing under the shifter and it's very difficult, some times impossible to shift into 5th/Rev. Does someone have a parts list and pics of what I need to convert the cable shift to rod shift?
Also thinking the diffuculty shifting into 5th/Rev maybe more than just the cable shift since I had to replace the tranny with one from a salvage yard. Could this be a problem with the tranny?
jusatad is offline
post #2 of 5 (permalink) Old 01-25-2013, 10:27 PM
jw89sho's Avatar
Cable to Rod shift is probably impossible, as the parts are discontinued and you would have to find a 91-95 SHO to harvest.
I have had to fabricate bushings for my shifter setup. The cable that moves with front-to-back motion I drilled and tapped the ball to install a screw and washer to retain the cable.
Josh
jw89sho is offline
post #3 of 5 (permalink) Old 01-25-2013, 11:23 PM Thread Starter
Chapter: Northern
i don't have a ball left in the shifter for front to back motion. Do you have a pic of what it is supposed to look like?
jusatad is offline
post #4 of 5 (permalink) Old 01-26-2013, 11:26 AM
May also pm member loudsho92.
post #5 of 5 (permalink) Old 01-30-2013, 12:12 AM
Cool
You can look here for the instructions: Rod Shifter Conversion :: SHOtimes FAQ :: Frequently Asked Questions (FAQ) about the Ford Taurus SHO from the SHOTIMES mailing list.
You will need to get a rod shifter from a 91-95 SHO. We do get rod shifters from time to time.
We also have the needed parts to fix the cable shifter: Drivetrain- Rod Shifter SHO Source - SHO Source
92 White SHO
loudsho92 is offline
