#11 (permalink) | |
Member Number: 50768
Drives: 2006 SEL
It could be something totally different then the brakes. Basically when I back out, the car won't move to far & you can feel & hear something grabbing. What it is I have no idea. I just assumed it had something to do with the brakes. Again it only happens in reverse so far. Engaging the park brake makes the grabbing worse. Last edited by groze; 01-13-2013 at 04:23 PM. |
#12 (permalink) |
Member Number: 7489
Look through the rear wheel spokes, if you see a shiny metal disc with what appears to be an oversized chunk of metal on it at around 10 o'clock (right side) or 2 o'clock (left side) you have discs. If you see uniform dull or rusty dull metal all around, that's the outside of a drum. If in doubt, take a photo or two and post them so we can help you determine.
Rear disc brake caliper mounting pins can develop rust spots that prevent the caliper from retracting. Brakes are the only stationary objects touching the wheels, so any grabbing will be brake-oriented; and since the parking brakes only are found on rear wheels, if the parking brake affects the problem - the problem is on the rear wheels. If you had a tranny problem, it would be affecting the front wheels.
Thank God we don't get all the government we pay for...
#13 (permalink) |
Member Number: 25751
Rep Power: 4 ![]() |
Brakes are not something to fool when you don't know if they are drum or disk. Take it to a brake shop and let them inspect for free and go from there.
#14 (permalink) |
Drives: 2006 SEL
Lgbpop
I hope you are right, that it is just the rear brakes. I never had brakes fail or go bad that way. The way the previous cars brakes failed is they slowly then stop working. All, Once the rear brakes are fixed, Do I need to use the parking brake everywhere or just on an incline? I am going to take it to a mechanic but can't get in for awhile. Ford Dealer is out of town. I hope it holds. |
#15 (permalink) |
Member Number: 7489
I am just making a guess, as educated as it may or may not be. Haven't seen it, obviously. However, it's logical based on your description - it doesn't rule out other possibilities.
You can do as you wish with your parking brake; I use mine almost all the time, but that's because my first car was a Corvair with automatic and that was the only way to keep the car from rolling. Good habit in my opinion.
#16 (permalink) |
I guess it based on what you call those brakes. I was raised calling them "emergency brakes" and was taught by my father how to use them incase your hydraulic brakes failed. Maybe before the double master cylinders of today and the automatic transmissions. I never used them on a manual transmission. Now they call them "parking brakes" and I guess you use for parking.
Groze, you may want to learn how to use them if all your hydraulic brakes fail. If you step on the pedal without pulling up on the release handle you will lock them up. |
#17 (permalink) |
Rep Power: 21 ![]() |
^ If rear drum set-up, may have a seized (frozen) wheel cylinder(s).
#18 (permalink) |
The Page 93 Mastermind
Member Number: 42443
C'mon guys! Easy stuff! It is a 2006 SEL sedan! They ALL had Drums.
I use my parking brake very frequently. When you release it, which you're saying it doesn't release all the way... pay attention to the sound. Is it making a quick release sound, or does it sound rather unresponsive? It is hanging up somewhere which definitely has to do with lack of use from the previous owner and maybe even rust/corrosion depending on where you live. You are engaging it 100% correctly so that isn't an issue there. Try this: Do a lot of repetitions to get it moving...just in park.. engage, release, repeat. And do this a few times and report back. I just think it is odd that in reverse it hangs up, but in drive it is fine!
Paul T. |2006 Taurus SE | Silver Frost |The 'Official' Bull of Central New York! | October 2012 COTM |2005 Taurus SEL| Vibrant White | The Stock Bull |1999 Taurus SE | Toreador Red | Retired with 112k |
#19 (permalink) | |
I would try actuating the parking brake. I would also drive the car in reverse and "pulse" the brake pedal a few times to actuate the adjusters. I would also check your brake fluid to see if it's low. You might have a leaking wheel cylinder that is causing things to stick inside the brakes. Or just let your mechanic figure it out. |
#20 (permalink) |
Don't forget, wheel cylinders can seize and not leak a drop of fluid.
