Unstable idle, p0420 p0430 - Taurus Car Club of America : Ford Taurus Forum
Old 01-08-2013, 04:33 PM   #1 (permalink)
Member Number: 52126
Drives: 2005 3.0 OHV
Jmxtwiztid is an unknown quantity at this point
Default Unstable idle, p0420 p0430
Figure its about time to join up, ive scoured this forum countless times and found information that always helps. This one has me at a loss though, please share your input!
2005 Ford Taurus 3.0 OHV
Symptoms:
Unstable idle (690-790) Needle bounces up and down
P0420
P0430
Small amounts of oil in upper plenum
Parts changed:
IAC
TPS
Intake plenum gaskets
IMT Oring
PVC Valve
Crankcase vent tubing
EGR connecting tube Oring
DPFE Sensor
Work:
Cleaned MAF
Checked all vacuum lines
EGR held 6 on the mityvac
Applied vacuum to EGR while idling, started sputtering, idle erratically
(I did the above to to check the operation of the EGR)
Freeze frame data p0420:
Fuel System: Closed loop
Load value: 65.8%
Coolant Temp:165 F
Short Term fuel trim 1: 0.8%
Long Term fuel trim 1: -2.4%
Short Term fuel trim 2: 3.1%
Long Term fuel trim 2: 4.6%
RPM: 1705
Speed: 46 mph
Ignition timing advance: 35.0
Intake air temp: 59 F
Air flow rate: 2.69 lb/min
Throttle position: 25%
Oxygen sensor 1 bank 1: 0.815v
Oxygen sensor 2 bank 1: 0.720v
Oxygen sensor 1 bank 2: 0.295v
Oxygen sensor 2 bank 2: 0.165v
Fuel pressure at idle 39-40
I'm at a loss as to what else it could be, I may have done more and forgotten it's been about a week so far, any input is appreciated!
Jmxtwiztid is offline   Reply With Quote
Old 01-08-2013, 05:26 PM   #2 (permalink)
I don't have any other symptoms that are noticeable other than the unstable idle, runs fine in the city and on the hwy at 80+, so I don't think the problem is actually the cats, I'm no expert though.
Old 01-08-2013, 05:32 PM   #3 (permalink)
Breeves002's Avatar
Member Number: 49890
Still seems like a bad IAC. How often do you change your oil? What weight oil do you use/what oil filter (or where do you go to get it changed?)?
2012 Kia Soul Base AT 1.6GDI
CLICK HERE
Old 01-08-2013, 05:46 PM   #4 (permalink)
WJC
WJC's Avatar
Member Number: 16719
WJC has a spectacular aura about
What is the long term fuel trim at idle with the engine fully warm?
WJC is offline   Reply With Quote
Old 01-08-2013, 06:14 PM   #5 (permalink)
5w20, motorcraft filter, every 4000. I should clarify that it used to jump alot more 2-300 rpms at a time, then after the new IAC 50-100 rpms at a time it helped a good bit. Ill go check on that WJC.
Old 01-08-2013, 06:17 PM   #6 (permalink)
Engine Temp: 201 F
Long Term fuel trim1: 14.8%
Long Term fuel trim2: 18.7%
RPM: 752
Fuel Rail Pressure: 46PSI
Fuel Level Input: 40.3%
Old 01-08-2013, 06:34 PM   #7 (permalink)
Also, bank 1 and 2 (p0420 & p0430) do those refer to the y pipe as bank 1 and the rear converter as bank 2?
Old 01-08-2013, 06:44 PM   #8 (permalink)
sheila is just really nice
Bank#1= firewall bank (po420). Bank#2= radiator bank (po430).
Old 01-08-2013, 07:03 PM   #9 (permalink)
Ok so both of those are on the y pipe and don't need to worry about the rear? Sorry my experience is more with diesel so i dont really know much about cats or emissions. Think I just got confused, there are only two cats on the car, one by the radiator and one under the car right before the resonator right?
Old 01-08-2013, 08:05 PM   #10 (permalink)
WJC
WJC's Avatar
Originally Posted by Jmxtwiztid View Post
Engine Temp: 201 F
RPM: 752
OK those are high, you're running lean at idle. I think you still have a vacuum leak.
