Member Number: 12596
Drives: 1997 Mercury Sable LS
Rep Power: 6 ![]() |
Hey Gang:
I've been on X-mas vacation and traveling through the Rocky Mountains when I got a P0305 MIL. I did some research about the P0305. When I got my P0305 MIL the engine wasn't under a load, I was going down the back side of a hill foot off of the accelerator. Since I was traveling I got gas at various locations. I want to get to the root cause why the P0305 tripped. Only thing I can think of right now is bad gas (water in fuel), the coil pack or vacuum leak. Right now I'm thinking vacuum leak or intermittent coil pack. If it is a vacuum leak can anyone give a list of the top 10 locations to check on a 1997 Duratec engine? My Motorcraft spark plugs have 30K miles on them. Thanks. Monsoon
>> In God we trust; all others bring data. >> Me Like MACH Audio... >> Factory Certified Glock Armor >> ASQ Certified Software Quality Engineer >> 220K+ Duratec Mile Club >> Motorcraft. What's in your Ford ? |
Rep Power: 21 ![]() |
Vac. leak(s) should trip po171/174 lean codes. Most common 1 on your eng. is the upper u-shaped pcv hose directly under the throttle body. Check/replace plug(s), wire(s) or coil for misfire code(s).
Member Number: 11378
Rep Power: 14 ![]() |
Do you have a scan tool with you that will show fuel trims? If so, they will tell you if you have a vacuum leak or not.
![]() Member Number: 49890
Well it probably isn't a coil because coils either don't work at all, or have issues under load. It would probably miss under load as well if it was a coil. (or am I wrong?)
I agree check fuel trims, but you probably don't have a vacuum leak if you don't have the P0171/141 like Sheila said. Go ahead and read the misfire sticky, should help you out: How to Understand and Diagnose Misfires
PCM runs a misfire check when you're coasting. It would probably be fuel or vacuum related.
#6 (permalink) | |
I think you nailed it. I've cleared the P0305 code and it hasn't returned. I'm going to look for the elbow piece beneath the throttle body and check for cracking / dry rot. Thanks gang. Monsoon
