Help, i have problems with the band serpent - Taurus Car Club of America : Ford Taurus Forum
Old 12-31-2012, 12:57 PM   #1 (permalink)
Member Number: 51936
Drives: SABLE 1997, AUTOMATICO, MOTOR DURATECH V6 3.0L
REYMOND is an unknown quantity at this point
Default Help, i have problems with the band serpent
IS NOT THAT HAPPENS, THE VOLTAGE OF THE BAND APPEAR TO BE APPROPRIATE, TO MAKE IT ROTATE MANUALLY MOVE ALL THE MECHANISMS, TO MOVE CARGO FROM ANOTHER CAR, MY CAR STARTS UP, BUT THE BAND AND ITS COMPONENTS remain immobile BY WHICH MY BATTERY DOES NOT HOLD A CHARGE. HOW DO I CHECK IF IT IS THE ALTERNATOR? ANYONE HAVE PHOTOS OR VIDEO THAT CAN HELP ME.
REYMOND is offline   Reply With Quote
Old 12-31-2012, 04:02 PM   #2 (permalink)
Breeves002's Avatar
Member Number: 49890
Okay. First don't type in ALL CAPS please!
You can test your alternator voltage. One way to do it is remove it and a parts store should test it. You can check for the voltage while the motor is running. Should be at least 14v at idle.
2012 Kia Soul Base AT 1.6GDI
Old 12-31-2012, 05:05 PM   #3 (permalink)
danhasenauer's Avatar
Member Number: 12182
Drives: a Taurus
danhasenauer has a spectacular aura about
He typed "band serpent" in there, I think his serpentine belt/"band" is slipping badly........"BUT THE BAND AND ITS COMPONENTS remain immobile".....he also mentions a coolant loss, I'm thinking that hose/pipe fitting under the Tec motor spraying on his belt. Been there.....
Hola Reymond!
Comprobar el tensor de la correa. Usted ha dicho que usted tiene el motor Duratec, y una pérdida de refrigerante. ¿Ha comprobado la manguera de refrigerante y montaje de tuberías que se ejecuta en el motor? Con el tiempo, se oxida hacia fuera y sprays de refrigerante directamente en la correa serpentina, haciendo que se deslice. (or something like that...Mi Espanol no es bueno....)
'96 LX DOHC Moonlight Blue
RIP 'Ol Blue - 09/2012
danhasenauer is offline   Reply With Quote
Old 12-31-2012, 06:27 PM   #4 (permalink)
Old 01-02-2013, 11:33 AM   #5 (permalink)
Thumbs up excelente español, mucho mejor que mi ingles
Hola Reymond!
Antes que nada muchas gracias, te cuento como sucedió todo, mientras conducía de pronto se encendió la luz del testigo de la batería en el tablero. de inmediato sentí que la dirección hidráulica dejo de funcionar por lo que se volvió pesada. Me detuve de inmediato y abrí el capo para ver que sucedía, me percate de una fuga de refrigerante por la parte de la tapa presurizadora, espere a que se enfriara, rellene el tanque con agua y coloque la tapa, después de esto encendí el auto de nueva cuenta, arranco sin problemas, pero la aguja que mide las rpm no acciona, el testigo de la batería sigue encendido, la dirección es muy dura.
Intente encender el auto por la noche y no prendió, me quede sin carga, recurrí a pasar batería desde otro vehículo y si prendió pero a los dos minutos de desconectar la batería auxiliar mi auto se apaga nuevamente. Revise a detalle y me di cuenta que la correa o banda que llaman serpentina no se desplaza, supongo que tiene una buena tensión puesto que no se ve floja y si la giro manualmente hace girar todas las poleas sin mayor esfuerzo, la cosa es que cuando enciendo el auto ninguna polea inicia el movimiento y por ende la correa y las demás poleas permanecen sin movimiento.
De casualidad sabes que pieza es la que genera el movimiento en esa banda??
Old 01-02-2013, 03:19 PM   #6 (permalink)
ALTERNATOR GOOD, THE MECHANIC DIAGNOSED THE FAILURE IS BECAUSE broke the crankshaft pulley.
HAVE ANY IMAGE TO CHECK PULLEY really CHANGE THE PART.
ANOTHER QUESTION ME THIS FAILURE COULD RESULT IN MORE FAILURES.
Old 01-02-2013, 05:43 PM   #7 (permalink)
Debe haber dañado o roto el chavetero de metal en el extremo del cigüeñal. Esta ranura es una pequeña barra de metal que encaja en una ranura y se convierte en la polea del cigüeñal. Usted tendrá que quitar y reemplazar la polea del cigüeñal y la chaveta.
El único fallo sería otra posible las juntas de culata, dependiendo de la gravedad del recalentamiento era.
Old 01-02-2013, 07:03 PM   #8 (permalink)
thanks
pulley of the image corresponds to a 3.0 duratec engine?
I have trouble finding it, appears to be rare and in a store that gives me hope but say they have two models, one that has only three holes and one with many more.
Old 01-03-2013, 12:50 AM   #9 (permalink)
Imagen anterior es 3.0L OHV Vulcan el motor.
Usted tiene el motor 3.0L DOHC Duratec?
Duratec pulso rueda:
Asegúrese de que la chaveta se alinea con el diente que falta.
Old 01-03-2013, 12:09 PM   #10 (permalink)
Default Este es mi motor
Cual de estas poleas es el damper??
