Member Number: 49671
Drives: 2000 Ford Taurus Vulcan engine
Hello all,
I need to know what kind of special tools which are required to remove/install the PS pump on my 2000 Ford Taurus with Vulcan engine. Based on my research, I need a special remover and installer in order to remove the pulley wheel from the pump. Here is my finding: OEM/Power steering pulley puller installer kit (27031) | Power Steering Pulley Puller/Installer | AutoZone.com Does this tool fit my car? Also, do I need a special tool to remove the high pressure line from the reservoir? Any thing I should pay attention? Thank you |
Member Number: 5295
Drives: 2005 Taurus SE
3.0L Vulcan
Rep Power: 16 ![]() |
That puller set should do you fine from what I can tell. As for wrenches, you will need an 18mm flare nut wrench and a 24mm open end wrench to remove the high pressure line.
Rep Power: 22 ![]() |
You can rent that kit for free with a deposit from AutoZone and other parts stores with a tool loaner program. May be good to use a flare-nut (line) wrench on the high line, but not absolutely necessary. If you want Xmas tools, the ps remove/install kit and sets of flare-nut wrenches are available for cheap at Harbor Freight Tools. Be sure to get the proper flare-nut metric set that includes the wrench size you need for the pressure line. Make sure you carefully mark/measure the position of the pulley on the old pump prior pulley removal and install it in the same location on the new pump. If you don't, you'll encounter belt alignment problems.
#4 (permalink) | |
![]() ![]() Which wrench (18mm or 24mm) I should hold solid and which one I should turn? I assume that I should turn the wrench which is near the high-pressure line with size of 18mm. Please correct me if I am wrong. Thank you |
#5 (permalink) | |
Thank you |
^ Yes. Depth on the pump shaft.
Hello all,
My friend forwarded me this picture and have no idea where I can get it from. Installer Set, Teflon Seal 211-D027 (D90P-3517-A) or equivalent Thx Updated on 01/08/2013. This post is very useful! Power Steering Question Last edited by ethankay816; 01-08-2013 at 01:36 PM. |
#8 (permalink) | |
Member Number: 5295
3.0L Vulcan
You would hold the 24mm wrench and use the 18mm flare wrench to turn the fitting. You may get away with using a regular open end wrench there, but in my case that was not going to work.
#9 (permalink) |
Member Number: 1771
Drives: 97 SHO Sedan, 00 SEL Sedan
YOu can use a tapered punch to roll the Teflon seal up enough to slide over the threads. Dental pick tools are helpful too. Buy two of those seals when you're at the dealer. Esp if it's your first time replacing them. IF you overstretch or tear one, you got backup
--Nick M. | Blythewood, SC | AAP/Atlanta Built Bulls -Silver Frost MC 2000 Ford Taurus SEL | DOHC/AX4N | 184K -Toreador Red MC 1997 Ford Taurus SHO | DOHC/AX4N | 149K --Wood paneled 1991 Mercury Grand Marquis LS Colony Park wagon | OHV/AOD | 180K ish? Sold.... --Driftwood MC 1987 Ford Taurus GL Wagon | OHV/AXOD | 254K - now owned by major!! Scrapped... --Sand Beige 1987 Ford Taurus GL |197K | OHV/AXOD |
#10 (permalink) |
^ Nick, does Dorman offer those teflon seals in their Help! section?
