#11 (permalink) |
Member Number: 1771
YOu know, that's right, they do. I forgot they started doing that.
#12 (permalink) |
Member Number: 3934
Drives: 2002 SES Vulcan
Good luck on getting the replaced pump quiet. If you do, let us know.
#13 (permalink) | |
Member Number: 49671
Drives: 2000 Ford Taurus Vulcan engine
http://image.made-in-china.com/2f0j0...d-Gas-Pipe.jpg Are they same? Also, how could I overstretch or tear the item? I cannot find any related topic in this PS replacement since other people don't use this special tool at all. Best |
#14 (permalink) |
Member Number: 51489
Drives: 2002 DOHC MERCURY SABLE
Rep Power: 2 ![]() |
In my experience when installing the new PS pulley with the tool u can rent from autozone you want to first remove the black paint from the inside of the new pulley with sand paper or dremel wire wheel.
Also spray a little bit of silicone on the pump shaft. How did I know this? I broke the pulley tool once cause the paint on the new pulley wouldnt allow me to press on the new pulley to the new PS pump shaft. It would just go so far then refuse to push on anymore. Lastly measure the distance between the pulley and pump so you know how fart to seat the pulley on the new pump. |
#15 (permalink) | |
http://www.rockauto.com/getimage/get...TP68RM-FRO.jpg I also assume I don't need to buy a new pulley but I may end up buying one. What do you mean "black paint"? Thank you |
#16 (permalink) |
Member Number: 1771
He means that with most new pulleys, there's black paint inside the hole for the pulley shaft to go through. Not always true and not really recommended. I'd rather slather the shaft of the pump in ATF. Then press the pulley on, it'll work fine. No sanding required.
#17 (permalink) |
Member Number: 17745
Drives: 3 Taurii .... 2001 Vulcan, 2003 DOHC, 2006 Vulcan
That is the problem I am having. I replaced the pump and the box has a sticker on it saying the pump makes noise. No Poo-poo! As far as replacing the pulley wheel, the box that the new/reworked pump comes in has the installation bolt/washer with it and instructions on how to install the wheel. Follow them and you will have no problem. However, it is pretty much a two man job. I did it by myself but I sure wish I had the grandson with me. The removal/installation is not hard, and I made a step by step report with pictures, but can't find it. Maybe it is on the downstairs computer. If anyone needs it, e-mail me and I will dig it up. A vacuum pump is not needed, but I also have the instructions on how to do it.
If someone knows of a coating that can quiet the dang thing down, please let me know. Dandur805@yahoo.com |
#18 (permalink) | |
Member Number: 3575
Rep Power: 11 ![]() |
Also, using white grease on the pump shaft will make installing the pulley a bit easier.
