Scan tool/Fuel trims - Page 4 - Taurus Car Club of America : Ford Taurus Forum
Old 12-13-2012, 05:31 PM   #31 (permalink)
Yes, it would be nice to have the data from the WOT/snap test and the solo O2 sensor test.
Right now I'm leaning towards you having intake valve deposits. Do you drive a lot of stop and go or have many hot-soak cycles?
Old 12-13-2012, 05:39 PM   #32 (permalink)
Taking Care of Business
04 SEL's Avatar
Member Number: 40467
Drives: 2004 SEL Duratec
04 SEL is a jewel in the rough
Ok I will do those tomorrow. No I don't do a whole lot of stop and go. At least I don't think I do...what would you consider alot?
Sent from my iPhone using AutoGuide.com Free App
Ben
2004 SEL, 60k miles, Vibrant White. 35% Tint, K&N Panel filter, Sylvania XtraVisions, Duralast CMAX, Remote Start, 4x Infinity Reference 6832cf, JVC KW-R800BT
04 SEL is offline   Reply With Quote
Old 12-13-2012, 05:46 PM   #33 (permalink)
Starting the car more than three times a day, leaving the car off for less than 30 minutes and restarting more than a few times a week, getting stuck in heavy traffic on a regular basis, city driving when you have to stop at a sign or light more than 3-4 times in a mile etc. Anything close to use like a pizza delivery boy.
Old 12-13-2012, 06:00 PM   #34 (permalink)
04 SEL's Avatar
Yes some days I start it more than three times a day. Usually at minimum three days a week I do this. Yes a few times a week the car is started less than 30 minutes after being shut off. No, I don't do a whole lot of stop and go whatsoever.
Ben
Old 12-13-2012, 06:30 PM   #35 (permalink)
04 SEL's Avatar
Today for instance, my car will have been started four times. Three times within an hour. 7 hours between the other one. No stop and go though. I might add that the car was likely not up to operating temperature for those first three so shouldn't have too much heat soak today
Ben
Old 12-13-2012, 07:52 PM   #36 (permalink)
Well, I don't think you're in the high risk group for deposits, but perhaps the moderate group. Unless you're the first owner you also don't know how it was driven by the previous owner.
I'll know a little more when I get the other test results. When I get the WOT MAF data I'll be able to see if your volumetric efficiency is okay or not.
Old 12-13-2012, 08:07 PM   #37 (permalink)
04 SEL's Avatar
PO was an older woman, drive it to work and church mostly. All in the same town, serviced at the dealer. Nothing major in that time though.
Ben
Old 12-13-2012, 08:35 PM   #38 (permalink)
Oh, I forgot to mention I'll also need some atmospheric parameters when you do the MAF run so I can get the air density. When you do the run record the outdoor temp and % humidity, and also report your elevation and current barometric pressure. If you just tell me the temp and where you did the run I can find a nearby weather station with the rest of the info as well.
Old 12-13-2012, 08:39 PM   #39 (permalink)
04 SEL's Avatar
Ok. Will do.
Ben
