#11 (permalink) | |
Member Number: 4508
Drives: 00tec
Rep Power: 15 ![]() |
#12 (permalink) |
Member Number: 49602
Drives: 2001 Taurus SES 3.0 liter V6
Rep Power: 1 ![]() |
You said it was 30 degrees might the smoking be from a leak in the heater hose? I had a problem like this with another vehicle and pin hole in water hose was culprit. I only noticed the leak on cold days, when I turned defrost or heater on. Water shot engine creating steam.
It might be the belt burning mentioned but you can check that by simply running the AC and seeing if you have the same problem not on defrost. If defrost only smoking on cold days when you run heater or defrost(heater/AC blend) then it's possibly a coolant leak. With recent water pump work I would look for leak in heater hoses. Hose is cheaper too! Good luck! |
#13 (permalink) |
Member Number: 51573
Drives: 2000 Ford Taurus flex fuel
I"m thinking its a hose leak.... because i can hear something dripping when the car is off and whatever its dripping on is making it smoke... thanks for all the insight guys!!!
this chick really appreciates all the help!
#14 (permalink) |
Member Number: 4508
Drives: 00tec
Coolant leaking and burning will have a sickly sweet smell.
#15 (permalink) |
Member Number: 32282
Drives: 1998 Taurus SE 3.0L DOHC Duratec 24V
Rep Power: 3 ![]() |
I just recently fixed a oil pan gasket on my 98 tec. It's been leaking since we got it in 07 and it started leaking ontop of the cat. I thought it was a belt or coolant (sweet + burning rubber) and left it alone for months. Defrost uses the outside vent over the cat, so during the winter months, I drove with the windows open.
This is what it looked like: https://dl.dropbox.com/u/19844487/20...2017.02.34.jpg https://dl.dropbox.com/u/19844487/20...2016.22.49.jpg Since the pan gasket replace, the Leak + Smell is gone.. I coulda swore the degass bottle was leaking, But taking a look around the cat quickly extinguished that theory. Edit: When my parents owned the car, A mechanic swore up and down it was the front seal leaking(why the gasket went this long); It was obviously the gasket, because the EPA violation in my driveway no longer exists.. Although if there is visible smoke and only appears when the heat is on; That might be a different story.. Last edited by Mystery101; 12-10-2012 at 10:56 PM. |
#16 (permalink) |
OK so update.... I got the coolant over flow tank replaced yesterday and now there is still a leak somewhere...looks like its coming from under the engine somewhere leaking on an exhaust pipe maybe? IDK the car started smoking really bad when i got to a red light this morning. The car was running fine yesterday after it was replaced only a little burn off smoke at that time but there is definitely somethig else leaking under the car. Im ready to just blow this stupid car up all the money its costing me to repair this thing.
#17 (permalink) |
I'll Be Watching You!
![]() Member Number: 37681
Could be the timing cover leaking.
#18 (permalink) | |
Do you have access to a jack + jackstands? or a ramp? Those would help determining the leak. Are there new wet spots(without a/c running) or oil spots on your driveway? |
#19 (permalink) |
Member Number: 11378
Rep Power: 14 ![]() |
Timing cover, water pump, heater core hoses / bypass hose assembly are common leak points that can drip on the exhaust. Timing cover leaks basically are due to lack of timely coolant changes (owner or previous owner neglect).
#20 (permalink) |
Member Number: 7669
Drives: 2001 SES Vulcan OHV (U)
Rep Power: 8 ![]() |
Smoking vs steaming are two different conditions.
In cold weather, coolant boil-off may resemble smoke but the smell should indicate whether it is smoke (rubber, oily smell) or coolant (unusual sweet smell). If you're not sure, a local shop can check it out for you - I have in the past taken advantage of my local Ford dealer's offer of an oil change and inspection coupon. They will list issues that you can then ask for quotes to repair, take it elsewhere or DIY. |
