Bleeding Brakes: Best Way - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 12-06-2012, 06:39 AM Thread Starter
Post the professional procedure to bleed brakes. I've been shown a few ways.
1....
2...
3...
Do I need to have new rotors cut?
My Taurus has stops fine but never a good quick stop.
Squiggle96 is offline
post #2 of 8 (permalink) Old 12-06-2012, 07:34 AM
fct
The best way is to do it with a helper.
First you need tools. Find out the size of wrench you need for the bleeder valve. I believe its 10 or 11mm. You need an open wrench (you can get a whole set of many sizes for like $10 at Harbor Fright Tools). You need a transparent hose that runs from the valve into a container. The fish tank utility hose sold at Walmart in pet section for like $3 works for me. Finally, you need some brake fluid. More is better. I use up like a quart when bleeding all brakes to make sure all of the old fluid was pumped through.
Jack up one side. Take the wheel off. Put the open (round) wrench on the bleeder valve. Connect one end of the hose to the valve and the other end into a container (soda bottle, etc). I use a set of thin pliers to stretch the end of the hose before fitting it on the valve (valve is a bit too wide).
Before proceeding further I'd recommend to use a long hose to siphon old brake fluid from the fluid reservoir, this will make the process a bit faster. Top off the reservoir with fresh fluid, all the way to the very top.
Now the real bleeding process.
1. Tell your buddy to press and hold the brake pedal
2. Open the bleeder valve
3. Close the valve when you see that fluid stopped flowing.
4. Tell your buddy to release the brake pedal.
5. Repeat.
Keep pumping until you see lighter (new fluid) coming through the hose, then stop. As you pump the brake fluid though the system, keep an eye on the brake fluid level in the reservoir. Top it off when necessary. If you let it go dry, air can get into the brake system and the whole process needs to be repeated. Pour the used brake fluid on the first baby seal you can find.. err delete this step. Return it on AutoZone, CarX, Walmart, etc.
fct is offline
post #3 of 8 (permalink) Old 12-06-2012, 08:52 AM
I always vacuum bleed brakes with a vacuum pump and a catch can. No helper needed and no pressing of the brake pedal.
post #4 of 8 (permalink) Old 12-06-2012, 09:41 AM
intimidator's Avatar
^+1...easiest way.
04 Taurus SES 3.0 Vulcan (gone)
03 Sable LS 3.0 Duratec (traded)
98 Contour Sport 2.5 Duratec (3 blown trannies racing)
97 Lincoln Continental 4.6 Intech (sold)
70 Yamaha Twin 250
00 F-250 SuperDuty 4x4 6.8 v-10 Triton( K.I.A. )
12 Taurus SEL 3.5 Duratec FWD
06 Magnum R/T 5.7 Hemi AWD
intimidator is offline
post #5 of 8 (permalink) Old 12-06-2012, 10:22 AM
Year: 2000
I also saw richpin06a covers the valve with some grease to prevent air being sucked in.
q0987 is offline
post #6 of 8 (permalink) Old 12-06-2012, 09:18 PM
I'll Be Watching You!
sousa632's Avatar
Model: Mercury Sable Wagon
Richpin knows his stuff! I almost forgot about that guy, you just took me back about 2 years when I had a Saturn wagon
John
2001 Sable LS Premium Wagon Duratec 192K miles and kicking
2013 Hyundai Sonata GLS
sousa632 is offline
post #7 of 8 (permalink) Old 12-07-2012, 01:58 AM
If your rotors are flat and not scored, (assuming they have enough meat
on them to meet minimum thickness), i would not have them turned.
It would cost about 1/2 as much as new Chinese rotors.
New ones should be good out of the box to use.
What i do do is take a file and file down the ridge that gets built up on
the outside edge of the rotors on both the front and back if needed.
I also clean all the crud out of the vent holes between the faces.
Run you clean fingers across them and feel for imperfections on the
surface. If they are scored, i would just buy new aftermarket units.
Or get lucky at the upull yard and find some virtually new rotors for
$10 or so each. (I have done that before). I have found new brake
pads/shoes in the back seats or trunks in cars at the Upull yards.
I got the shoes on my 97 this way.
Also, make sure you rear brakes are working and NOT stuck or jammed.
Its easy to overlook this. On my 97, i had one side of a wheel cylinder
stuck solid in its bore. My 98 had a stuck rear caliper. even though
the front brakes do most of the work, having the rear brakes not up
to par will make it appear your brakes are not as good as they should be.
soundu is offline
post #8 of 8 (permalink) Old 12-07-2012, 02:39 AM
fct
One simple but slow way to bleed the brakes is simply open the bleeder valve and let the fluid flow out under gravity. This is a very slow process (could take hour or longer instead of 5 minutes), and you need to be around the whole time in order to top off the brake fluid reservoir when necessary. This is how I did it the first first time.
fct is offline
